Results 1 to 5 of 5
Thread: Can you pick up type parameters from a family host in a project?
    May 8, 2014
    70
    07:15 AM
    I seem to remember seeing something along these lines before, not sure if it's possible or not...
    Looking to create a family, simple fin plate to pick up parameters from the OOTB beam or column family (not necessarily both in same family, 2 separate families).
    So relate the height of a fin plate to the host beams distance between fillets for example.
    Is this possible? If so can it be simply explained here or am I better just muddling along with a bit of direction?
    Thanks in advance.
    Gold Coast
    2,626
    05:15 PM
    Making your fin plate a shared nested component inside the beam family might be easiest. If you have a separate family dependent (such as aligned/locked?) on the geometry of another in the project it might get ugly. Otherwise you're back to manually inputting dimensions or swapping types to keep things correct.
    I have no idea what a fin plate is but there is the Revit extensions addin (free on subscription) that auto generates structural reinforcement and connections, and there are other 3rd party addins out there too.
    May 8, 2014
    70
    07:15 AM
    I've explored the 2013 extensions today, very briefly in between 'billable work', and they seem tidy. I will have a more careful look when I get the time and explore the 2015 version also.
    Thank you Elton.
    However, could someone just confirm or deny if the pulling instance or type parameters from a host thing is possible as I can see several different uses for that if I can figure it out.
    Gold Coast
    2,626
    05:15 PM
    I use a custom shared instance parameter in nested families called 'host', which is linked through to the description parameter of the host family. In the project if tab-select (or schedule) the nested family I can see the host's description written to the 'host' parameter in my selection. AFAIK there is no way to achieve this from 2 separate families that are not nested in one way or another. There are also addins (cant remember right now) that will copy text data from 1 parameter to another, even though it;s faster than one at a time it is still a manual process that requires coordination/ manual updating.
    May 8, 2014
    70
    07:15 AM
    Thanks again Elton.
  1. Family Type Parameter aware of Host
    By GMcDowellJr in forum Architecture and General Revit Questions
    Last Post: July 8th, 2014, 03:52 PM
  2. Pick Primary Host
    By kirklyncox in forum Architecture and General Revit Questions
    Last Post: April 25th, 2014, 08:09 PM
  3. Revit OpEd: Pick New - Changing a Host
    Last Post: March 26th, 2014, 05:15 PM
  4. Revit OpEd: Pick New Host for Connectors
    Last Post: December 3rd, 2012, 01:15 PM
  5. Parametrically Pick Family Type
    Last Post: August 16th, 2012, 10:06 PM
