Results 1 to 3 of 3
Thread: Parametric Tag or beams and/or other elements
    October 13, 2014
    13
    05:20 PM
    Hello
    I am trying to create a beam tag family that allows me to select different parameters to display within the tag without having several type groups
    eg
    material - name - suffix 1 - suffix 2 - comment
    Currently if I had all of these as separate types I would have around 36 types :S
    If there any way I can make the label parameters a tick box or something within the properties box of the tag itself
    Cheers
    May 30, 2011
    4
    10:20 AM
    If I'm understanding you properly the way we've done it is to add a visibility parameter to the various labels inside the tag family and check them on and off as we require them.
    Mr. Revit OpEd
    2,861
    09:20 AM
    Tags don't support using instance parameters to control the visibility of labels. I can see why it could be useful if they did but it does contradict Revit's "type" ideology.
    I believe the reason for the current behavior is to ensure consistency from one type of tag to another. Allowing the instance based toggling of information in the same type of tag means we can't ensure the same information is always presented with a particular tag type.
  1. Joining Link elements with project elements
    By Burrito in forum Architecture and General Revit Questions
    Last Post: November 14th, 2017, 10:16 AM
  2. Beams
    By steffe in forum Architecture and General Revit Questions
    Last Post: May 28th, 2014, 02:03 PM
  3. How to get rid of gaps between beams.
    By wadedrafting in forum Structure - General Questions
    Last Post: May 13th, 2014, 07:29 PM
  4. Is Revit a Parametric Designing software Or simply a Parametric Drawing one?
    By smshiran in forum Architecture and General Revit Questions
    Last Post: November 18th, 2012, 11:48 AM
  5. Beams NOT snapping to beams at same elev. but with different ref. plane
    By sebaldsl in forum Structure - General Questions
    Last Post: March 2nd, 2012, 02:01 PM
