Results 1 to 3 of 3
Thread: Hollow core slab makes files too big
    July 29, 2013
    10
    07:53 AM
    Hello
    I'm having problems with one of hollow core slab family. The biggest problem is the size of it. Using it in 5000 square meter building makes it over 5 times bigger than it originally was. IFC files are going to a gigabyte and when switching to a basic Autodesk family it goes back to 50 or so Mb. Could someone give a look and see what is making it so big
    Second problem is when i cut it. It has a masking region on it to hide the lines which are created by the edge. When the slab is cut by face then the masking region dissappears totally and the nasty multi-edged slab appears.
    Does anyone have answer to ANY of my questions. Any help is welcome.
    Attached Files Attached Files
    July 29, 2013
    10
    07:53 AM
    As I have played a lot with this family I realized that the complexity of the shape has been pumping up the size of the file
    Is there any way to make it smaller?
    Any ideas at all...
    If someone cares then I solved the problem by creating two sweeps. One which is used in medium detail and is just a solid block and one with the holes and profiles. As i create IFC i simply change the detail level to medium which shows the solid blocks and the holes through the beams are shown and IFC size is reduced from 700mb to 7mb
    December 23, 2013
    Kent
    11
    08:53 AM
    If I have too model Hollow Core Planks I just model the whole area as a Slab/Floor with the thickness and material of the Hollow Core plank. Then in Section I have a 2D Family of the Hollow Core Plank that I just drag and drop in the section and detail views. Otherwise your model size does go through the roof.
  1. Avioding auto-join with Hollow core slab?
    By Profiil in forum Structure - General Questions
    Last Post: November 27th, 2013, 01:45 AM
  2. Hollow core family. Void problem
    By Goahead in forum Architecture - Family Creation
    Last Post: July 25th, 2013, 10:45 PM
  3. Hollow Core Precast Slab - Custom Width
    By kev4174 in forum Structure - Family Creation
    Last Post: January 9th, 2012, 08:13 PM
  4. hollow core floor slab
    By cadtech in forum Structure - General Questions
    Last Post: October 10th, 2011, 10:19 PM
