Results 1 to 3 of 3
Like Tree1Likes
  • 1 Post By Alex Cunningham
Thread: Help with Bolt Family Required
    October 23, 2012
    1
    07:04 PM
    Hello
    So I have created a bolt family that works perfectly in the family creator - all of the types work as expected. However when I insert it into a project file it only lets me use the family type that was current when I imported it? When I go to change family type it says 'unable to create.....'
    At first I thought I was because the project units were rounded to 1mm so it wasn't able model the bolt correctly but then updated these to 3 decimal places and still no joy.
    Before you ask why I'm modelling bolts anyway this is for a Navisworks animation and not for use in a large project
    Any help would be appreciated as I thought I'd nailed this bolt and now I've hit a brick wall
    Thanks
    Mark
    (bolt attached)
    Attached Files Attached Files
    Alex Cunningham's Avatar
    December 8, 2010
    Northern California
    3,567
    11:04 AM
    Try moving your constraint dimensions out of the extrusions and to reference planes. It looks like you are kinda making the family in the wrong order. Bones, Muscles, Geometry.... Steve Stafford has some very good blog posts about it here and here. Basically draw the reference planes, then constrain them with dimensions. Flex your bones (reference planes) with your muscles (dimensions) before assigning geometry to anything.
    Robin Deurloo likes this.
    January 12, 2012
    2
    07:04 PM
    The parameters driving the geometry all seem to work for the different types you set up. Did you start with a face-based generic model template? Thats best for bolts as you will normally be placing them in a 3d view on a plate or steel member. Try rebuilding the family from that template with your parameters & planes outside the extrusions a suggested above, & lock the geometry to planes, not the ref level. Bolt length should be an instance parameter also. See the attached example of a very simple bolt family, that works in a similar way to yours, just without the chamfers and washer. Good luck!
  1. Anchor Bolt Family Help
    By dzatto in forum Architecture - Family Creation
    Last Post: August 2nd, 2017, 09:29 PM
  2. Window Family Problem - urgent help required
    By tomphillipsarchitect in forum Architecture - Family Creation
    Last Post: August 25th, 2014, 02:46 PM
  3. Replies: 7
    Last Post: June 4th, 2014, 03:58 PM
  4. Tricky Revit Family Required
    By Des in forum Architecture and General Revit Questions
    Last Post: July 16th, 2013, 03:15 AM
  5. Bolt family dutch
    By Bross in forum Structure - Family Creation
    Last Post: September 28th, 2012, 02:27 PM
Tags for this Thread
