Results 1 to 7 of 7
Thread: Column with variable depth
    September 13, 2014
    4
    01:31 PM
    Hi everyone
    Could anyone tell me how to create a column with a variable depth in my model ?
    OR if there is a specific Family already exist for that kind of column, Could you please upload it or give me a link where i can download it from ?
    Thanks in advance
    Moderator cellophane's Avatar
    August 9, 2011
    Louisville, KY
    6,143
    07:31 AM
    You can adjust the base offset of your columns independently using the properties palette. Columns can also be attached to a floor, other structural members or reference planes if you need additional controls.
    Attached Thumbnails Attached Thumbnails Column with variable depth-column-properties.png
    September 13, 2014
    4
    01:31 PM
    Problem is not solved ...
    to make it clear ... i want to create a column with (300mm x 600mm) at the top section and (300mmx300mm) at the base section.
    June 13, 2014
    Milwaukee
    232
    05:31 AM
    You can create a column family that is a blend with parameters that control the top and bottom size.
    September 13, 2014
    4
    01:31 PM
    I'm a newbie with family creation ...
    i'll appreciate if you have anyway to show me "How"
    All i got is this
    June 13, 2014
    Milwaukee
    232
    05:31 AM
    I cannot help at the moment. I am about to leave for class. Tonight when I get home I will create a sample file and post it here so that you can see how it is done. I find the best way to learn is by doing. If someone else has one already and can help out in the mean time that would be great.
    This is the instruction that I can give you now.
    You would create the base profile on the first floor plan view. First create reference lines that would constrain the object such as length and width.
    Draw your profile and align them to your reference planes so that you can then lock them to the reference lines
    Create dimension parameters to control base width and base length
    Dimension your reference planes and assign the parameters Base Width and Base length to them accordingly
    Do the same for the top profile as well. Either use a second level as the constraint for this or create a horizontal plane at an elevation above the first floor
    Create a height parameter and dimension the reference planes and assign the parameter to it in the elevation view.
    This is just a brief outline of how it is done more info to come. I am assuming that you are using a square/rectangle profile
    September 13, 2014
    4
    01:31 PM
    Quote Originally Posted by dtp81390 View Post
    Thank you very much, I really appreciate your efforts , I will try it
    Thanks again .. have a nice day
  1. Revit 2014: Wall join to Column overides column display
    By MrBIMtastic in forum Architecture and General Revit Questions
    Last Post: June 20th, 2015, 12:09 AM
  2. Variable 'If' Statement
    By Nevin in forum Architecture - Family Creation
    Last Post: June 5th, 2014, 06:25 AM
  3. Beam with Variable Sections
    By Inflames85 in forum Structure - General Questions
    Last Post: December 7th, 2013, 11:51 AM
  4. Mirror - variable dimentions?
    By cath in forum Architecture - Family Creation
    Last Post: February 29th, 2012, 03:15 PM
  5. Variable beam creation
    By lucis29 in forum Architecture and General Revit Questions
    Last Post: April 8th, 2011, 01:53 PM
Tags for this Thread
