Results 1 to 5 of 5
Thread: Unique parameter values from hosted family
    July 29, 2013
    10
    02:40 AM
    I have a problem with getting unique parameter values from the host family.
    I have created a pile(as a stick) family and added an shared parameter into it. Then i put this pile family into pile cap family.
    The problem is when i use it in the project and my pile cap has more than 1 piles in it, they will inherit the same value.
    How could i give the piles different parameter values. I can only give the parameter a value by giving it to the whole family, i need to give it to the piles itself.
    Thank you
    Orlando, FL, USA
    3,098
    10:40 PM
    There are, at least, 2 options:
    Option 1) In the host family, create several copies of the nested pile. Also, create one parameter for each property of the nested pile. (e.g. "size of pile_1", size of pile_2", ...). Then link the parameters of each instance to its correspondent unique parameter in the host. (e. g. first pile to "size of pile_1", second pile to "size of pile_2", ...). Even if you have several instances of the same nested family, its parameters can be linked to different parameters in the host file.
    Option 2) Set the nested family as shared. Load this shared family into the host, and create multiple instances of it in the host family. Then, in the project, use the Tab key to select each pile, and then enter values to modify its instance properties.
    (EDIT: See my next post for correction/additional instructions).
    July 29, 2013
    10
    02:40 AM
    Thank you for the answer but it does not work.
    May I describe the problem with my example.
    I have a small family which is used to gather coordinates for my piles. A small family called Einfügepunkt. i have added it a description which is made into shared parameter.
    Einfügepunkt is added on the top of every pile. And 4 of the piles which include the coordinate thingy are added inside the Pile cap family. And when i go in the project then I can only change the Pile Caps description (shared parameter) and when I use tab to select individual piles, then the Description is GREY and cannot be changed.
    Someone please give some hints or when it is not possible, SAY so : )
    Thank you
    Orlando, FL, USA
    3,098
    10:40 PM
    In the host family, link the shared parameter of each nested shared pile to a unique instance parameter (if you need to schedule this parameter, make it instance, too). In the project, select the main host family, and enter a value for each parameter, such as "Id_1", "Id_2", ... etc.
    July 29, 2013
    10
    02:40 AM
    Thank you very much !
    Worked like charm (Y)
  1. migrate from Family Parameter to Shared without resetting values?
    By spotless in forum Architecture and General Revit Questions
    Last Post: January 17th, 2014, 07:48 PM
  2. Visibilty Parameter with multiple OR values
    By Grumple in forum Architecture - Family Creation
    Last Post: November 5th, 2013, 04:32 PM
  3. Yes/no parameter related with numeric values
    By prawin92 in forum MEP - Family Creation
    Last Post: May 25th, 2012, 05:15 AM
  4. Shared Parameter File: Is name only unique or name/group
    By jerry_fci in forum Architecture - Family Creation
    Last Post: December 2nd, 2011, 10:21 PM
  5. Parameter values
    By bangobeat in forum Out There
    Last Post: October 26th, 2011, 12:27 AM
