Results 1 to 2 of 2
Thread: How can i put constraint to this column shape
    July 7, 2014
    27
    07:54 AM
    Aِs per attachment i have two types from this column, the problem i can't put constraint to be able to create the 2 types, every constraint is conflict with the other.
    so any ideas to create these
    Type 1
    Type 2
    July 7, 2014
    27
    07:54 AM
    OK i solved it, i was put the parameters after extrusion, it should be into the extrusion.
  1. Arc Column shape how to create?
    By dedo in forum Structure - General Questions
    Last Post: August 18th, 2016, 06:26 AM
  2. Revit 2014: Wall join to Column overides column display
    By MrBIMtastic in forum Architecture and General Revit Questions
    Last Post: June 20th, 2015, 12:09 AM
  3. Angle adjustable l shape rc column
    By kedyboy in forum Structure - General Questions
    Last Post: March 22nd, 2013, 08:35 AM
  4. Wall Top Constraint Error
    Last Post: August 10th, 2012, 02:50 PM
  5. Column Shape Issue
    By Yan Naing Bo in forum Structure - General Questions
    Last Post: September 9th, 2011, 03:00 PM
