Results 1 to 6 of 6
Like Tree2Likes
  • 1 Post By PijPiwo
  • 1 Post By PijPiwo
Thread: Chamfers to a concrete beam?
    August 28, 2014
    24
    06:47 PM
    Wondering whether anyone can help!? and suggest the best way to go about this...
    Basically I have a piled retaining wall, which requires a capping beam to the top of it. Simple enough so far...
    BUT the concrete beam is required to be chamfered.
    Initially I attempted to model in place a void form and then cut the geometry of the beam, but this doesn't seem to work.
    So the potential next alternative I see is to create a family for this beam with the chamfers..If this is the way to go, I am a little stuck as when I create the chamfer, the D & W of the beam default to a constant value and it won't allow me to change it.
    If anyone can shed a little light on to this it'd be appreciated!
    Cheers
    "OMG I killed Revit"
    dzatto's Avatar
    December 9, 2010
    5,234
    12:47 PM
    Is your retaining wall level at the top? Wall Sweep with a profile?
    Can you post a pic?
    August 28, 2014
    24
    06:47 PM
    Quote Originally Posted by dzatto View Post
    Can you post a pic?
    Thanks for the reply,
    Image attached. As you can see, it is a capping beam to a secant piled wall. The beam is modelled through structural framing. I require a 100mm chamfer to the bottom two corners.
    Attached Thumbnails Attached Thumbnails Chamfers to a concrete beam?-pic.png
    Senior Member PijPiwo's Avatar
    May 20, 2011
    Chicago, IL
    787
    12:47 PM
    You can modify the profile in your beam family.
    Attached Thumbnails Attached Thumbnails Chamfers to a concrete beam?-beam.jpg
    dzatto likes this.
    August 28, 2014
    24
    06:47 PM
    Quote Originally Posted by PijPiwo View Post
    Thanks, although I initially tried this and it somehow messed with the parameters for specifying the width/depth of the beam...it would only come in at one random size for some reason.
    I'll give it another try!
    Cheers
    May 20, 2011
    Chicago, IL
    787
    12:47 PM
    Make sure the profile lines are locked with the ref. planes.
    BigIdiot likes this.
  1. Concrete beam schedules?
    By LeanneZ in forum Structure - General Questions
    Last Post: January 26th, 2016, 01:31 AM
  2. Concrete beam to column connection
    By ahmed_nox in forum Structure - General Questions
    Last Post: September 15th, 2014, 06:09 AM
  3. Creating a void through concrete slab and beam
    By jh75 in forum Structure - General Questions
    Last Post: November 27th, 2013, 03:27 PM
  4. Cantilever Concrete Beam
    By gdoherty0102 in forum Structure - General Questions
    Last Post: November 15th, 2012, 07:40 PM
  5. Beam Joins for Concrete Rectangular Beams
    By Yan Naing Bo in forum Structure - General Questions
    Last Post: February 10th, 2012, 02:25 PM
