Results 1 to 3 of 3
Like Tree1Likes
  • 1 Post By Alex Cunningham
Thread: Structural Angle & Channel Column family
    August 6, 2012
    Montreal
    111
    11:52 AM
    I' would like to create a Structural Angle & Channel Column family. I tried to understand the "out of the box" beam angle family so that I could mimic the shape selection dialog box. I saw that it's an actual sweep using a loaded profile. When I look @ the profile family i don't see any lookup table or whatsoever? How are the shape size control in theses family?
    Basically i want to create a family from which you are presented all the shapes & you just pick the one you need (like the default columns family in revit).
    any suggestion?
    Alex Cunningham's Avatar
    December 8, 2010
    Northern California
    3,567
    09:52 AM
    See attached families and type catalogs. These are part of the out of the box families that come with Revit.
    Edit:
    I just noticed you are from Montreal, you might want the metric families. Look here. C:\ProgramData\Autodesk\RVT 2014\Libraries
    Attached Files Attached Files
    thanhhung3558 likes this.
    August 6, 2012
    Montreal
    111
    11:52 AM
    Whoaaa... I did not see theses one.... Thanks again for your help!!
  1. Structural Column family different between RAC and RST version
    By Parametric Snowman in forum Architecture - Family Creation
    Last Post: December 17th, 2013, 12:02 AM
  2. structural column and analitical model
    By sink69 in forum Structure - General Questions
    Last Post: November 4th, 2013, 01:14 PM
  3. Angle adjustable l shape rc column
    By kedyboy in forum Structure - General Questions
    Last Post: March 22nd, 2013, 08:35 AM
  4. Please kindly check my Lipped-Channel Family
    By Yan Naing Bo in forum Structure - Family Creation
    Last Post: September 2nd, 2011, 02:52 AM
