Page 1 of 2 12 LastLast
Results 1 to 10 of 13
Thread: Rotating an extrusion
    March 29, 2013
    Fort Lauderdale
    56
    09:19 PM
    I am new to revit family creation. I need to be able to rotate a family in all planes. I created the extrusion using reference lines only. When I flex without the extrusion it works perfectly fine. With the extrusion, not so good. When i lock my extrusion to the reference lines it will flex with the width and length parameters, but not rotate. I attached the file. Hope someone can help me.
    Attached Files Attached Files
    Orlando, FL, USA
    3,111
    10:19 PM
    Welcome to the forum (and to the family editor). There is a recent post with the same topic and title. Please use the search function before posting. Please refer to: http://www.revitforum.org/architectu...extrusion.html
    March 29, 2013
    Fort Lauderdale
    56
    09:19 PM
    Actually, i tried using that thread, and it did not work for me. Thank you though
    Orlando, FL, USA
    3,111
    10:19 PM
    But then, what's the point of starting a new thread with the same topic? Sorry that the advice in that other thread did not work for you, but starting a new thread is not going to make any difference.
    March 29, 2013
    Fort Lauderdale
    56
    09:19 PM
    Sorry, to offend you, but not all situations are the same. I followed the steps, (word for word), creating the family in a separate family and loaded into the family with the angular parameter. Set the workplane to the the reference line. I probably should have commented on the thread already created. Sorry about that, but once again I am new the forum, and am learning the proper procedure. Thank you for the help.
    Orlando, FL, USA
    3,111
    10:19 PM
    The second paragraph of post #6 in that thread contains the instructions. What in that workflow didn't work for you? You must have missed a step somewhere.
    "I am NOT a Revit tutor!"
    Dave Jones's Avatar
    4,505
    07:19 PM
    Quote Originally Posted by floridashaughn View Post
    Hi and welcome to the forum! I don't thing that Alfredo was offended, he was just giving you some posting etiquette guidance As you have now surmised, if you find a thread with a similar problem to what you are experiencing and what has been posted there doesn't work for you the thing to do is add a post to that thread with additional information like, what my family is trying to do, how my family is different than those previously posted, etc. Give the original thread posters a chance to figure out why you are having problems. I'm not a rotation rig expert so haven't looked at your posted family but I'm sure you'll get a lot of responses tomorrow when the long weekend (in the USA) is over...
    edit: OR, Alf will help you fix it today
    Orlando, FL, USA
    3,111
    10:19 PM
    Quote Originally Posted by Dave Jones View Post
    ... but I'm sure you'll get a lot of responses tomorrow when the long weekend (in the USA) is over...
    That's true. Only those who didn't have any special plans for this long weekend are still here.
    December 21, 2010
    C.LONDON
    4,392
    03:19 AM
    I never have plans for weekends. Long or short.
    March 29, 2013
    Fort Lauderdale
    56
    09:19 PM
    The only thing I can think of that I may have done different was that I am trying to rotate in left view. So, I went back, and tried to follow the directions again that you posted, using plan view. I rotated the loaded family, and then edit work plane, and picked the reference line. The extrusion is not rotating with the reference line with the locked angle parameter.
  1. rotating an extrusion
    By MattMc in forum Architecture and General Revit Questions
    Last Post: July 1st, 2014, 01:55 AM
  2. Roof Extrusion
    By paulwoody in forum Architecture and General Revit Questions
    Last Post: May 16th, 2014, 09:21 AM
  3. Extrusion with Array
    By Bjenk8100 in forum Architecture and General Revit Questions
    Last Post: November 21st, 2013, 08:01 PM
  4. Rotating a railing? Not sloping. . . .Rotating. Possible?
    By Stuntmonkee in forum Architecture - Family Creation
    Last Post: August 27th, 2012, 04:47 PM
  5. traduction 1: extrusion par chemin en 3D
    By jbenoit44 in forum Tutoriels, trucs et astuces en français
    Last Post: December 14th, 2010, 08:07 PM
