Page 1 of 2 12 LastLast
Results 1 to 10 of 11
Like Tree3Likes
Thread: Castellated Beams - Custom
    April 7, 2014
    South Africa
    12
    07:58 PM
    Hi All,
    Can someone explain so me, what all these "CASTELLATED BEAM PARAMETERS" stand for. I want to create a diff family. I need to create a 609x140x39 I.
    Example
    d1 -
    bf -
    1t -
    f1 -
    tw1 -
    k1 -
    Its crazy.
    Thanks
    Moderator cellophane's Avatar
    August 9, 2011
    Louisville, KY
    6,143
    01:58 PM
    They relate to the beam properties.
    d = height
    bf = flange width
    and so on
    Since castellated beams are made up of two pieces that can be different size members you need to be able to select the sizes independently
    d1=height(top)
    d2=height(bottom)
    etc
    if you look at the OOTB beam the parameters in the profiles are linked to the different family parameters
    Alex Cunningham's Avatar
    December 8, 2010
    Northern California
    3,567
    10:58 AM
    I would recommend opening the Manual of Steel Construction and flipping to the Dimension & Properties section. In my book its the first section.
    "I am NOT a Revit tutor!"
    Dave Jones's Avatar
    4,491
    10:58 AM
    Quote Originally Posted by Alex Cunningham View Post
    two questions, me being the curious type: Is the MoSC available in metric format or is this US documentation? And, what's the current issue of the MoSC? I'm using the 1980 8th edition. Probably should spring and upgrade
    April 7, 2014
    South Africa
    12
    07:58 PM
    d = height
    bf = flange width
    and so on
    d1=height(top)
    d2=height(bottom)
    etc
    That image helps a lot. Not I can refer to steel handbook for properties!
    Where did you get that picture if I may ask.
    Thanks a lot for the help
    August 9, 2011
    Louisville, KY
    6,143
    01:58 PM
    google
    that is for a wide-flange beam but the castellated beams are frequently composed of two WF sections.
    Senior Member PijPiwo's Avatar
    May 20, 2011
    Chicago, IL
    787
    12:58 PM
    Quote Originally Posted by Dave Jones View Post
    I’m not sure what the latest edition is, but I’m using this pdf document (2002 edition) for all of my steel needs. The table with US standard sizes (imperial and metric) begins on page 127.
    …oh, and it’s free
    December 8, 2010
    Northern California
    3,567
    10:58 AM
    I am using the 3rd....
    Quote Originally Posted by PijPiwo View Post
    …oh, and it’s free
    Did PijPiwo answer your questions?
    Dave Jones's Avatar
    4,491
    10:58 AM
    cripes, and here I thought I was in the dark ages....and, yes, he did, thanks for asking
    December 8, 2010
    Northern California
    3,567
    10:58 AM
    I wanted to make sure... you are getting up there in age and i know your nod off from time to time.
  1. No Beams Were Added...
    Last Post: June 1st, 2015, 05:57 AM
  2. How to get rid of gaps between beams.
    By wadedrafting in forum Structure - General Questions
    Last Post: May 13th, 2014, 07:29 PM
  3. Beams NOT snapping to beams at same elev. but with different ref. plane
    By sebaldsl in forum Structure - General Questions
    Last Post: March 2nd, 2012, 01:01 PM
  4. Beams and holes....again
    By jbenoit44 in forum Structure - General Questions
    Last Post: January 12th, 2012, 09:38 PM
  5. Beams are not visibel
    By jhn in forum Architecture and General Revit Questions
    Last Post: November 15th, 2011, 11:49 AM
