Results 1 to 5 of 5
Like Tree2Likes
  • 2 Post By Alex Cunningham
Thread: Adding Cut Length to Structural Framing Tag
    April 28, 2014
    5
    12:16 PM
    Does anybody know how to edit the structural framing tag family so that the cut length is displayed in the tag?
    April 28, 2014
    5
    12:16 PM
    Or at least, is there a way to add a callout of some sort to a beam that will show it's cut length?
    Alex Cunningham's Avatar
    December 8, 2010
    Northern California
    3,567
    11:16 AM
    Yes
    Edit your framing family. Created a shared parameter called "What ever you want" with the "length" type of parameter. Add a dimension to the same reference planes that are being controlled by the "Length" parameter in the family. Select the dimension you places and in the options bar right under the ribbon do the pull down for Label. <Add a Parameter...> Locate your shared parameter you created. It will automatically make this a reporting parameter. Load the framing family into your project.
    Next you will need to edit the structural framing tag family and add a label to the family that reads this reporting parameter that you setup in the framing family. Do this by editing the structural tag family. Place a new label. Add a parameter. Select your shared parameter. Then add it to the label. Load into your project.
    One thing to note is the reporting parameter only like to read the length the first time you place the tag. Updates to the reporting length doesn't happen. Maybe somebody with far more experience with reporting parameter can weight in on a solution to this. Maybe you need to add the shared parameter to the project...
    Anyways I hope this was a clear walk thru for getting your beam length to report into a tag.
    elton williams and kirklyncox like this.
    April 28, 2014
    5
    12:16 PM
    Yes, thanks you!
    That works for displaying the length. The cut length on my parts is different and that's what I'm trying to display. I tried adding annotation to the actual part in the family instead of the reference line and that didn't work.
    I also have something weird happening with these labels. sometimes it displays the correct information and other times it doesn't.
    I don't want to have to double check every single label every single time I make a change... I have not been using revit for a long time but I really don't get some things. There is clearly a structural parameter called cut length that is already there. Why can't that be displayed in a tag? Why does revit care what I want to display in a tag so much. I can add 100 different useless parameters to the tag that nobody would ever want to show but for some reason cut length isn't available?
    I mean, look at some of the stuff I can easily add to a label that is pulled right from the same place as the where the cut length is.
    December 8, 2010
    Northern California
    3,567
    11:16 AM
    If you are looking for Cut Length add the reporting parameter dim string to the reference planes that are controlling the geometry in the beam family.
    The tag seems to only update and display the correct dimension on first placement.
    I know I know I know... we just gotta roll with the punches sometimes. You can schedule the cut length and length.... if that helps at all.
  1. Structural Beams (Length)
    By kowen1208 in forum Architecture - Family Creation
    Last Post: August 28th, 2013, 04:11 PM
  2. Schedule Total Length of Structural Framing
    By Ryan_Javlyn in forum Structure - General Questions
    Last Post: July 3rd, 2013, 05:02 PM
  3. Structural Columns Visibility og Length in Properties
    By ptranberg in forum Structure - General Questions
    Last Post: February 15th, 2012, 02:19 PM
  4. structural framing tag
    By r7_human8y in forum Architecture and General Revit Questions
    Last Post: December 6th, 2011, 05:59 PM
  5. IFC - how to export length instead of cut length on framing
    By leetkinda in forum Structure - General Questions
    Last Post: August 17th, 2011, 05:38 PM
Tags for this Thread
