Results 1 to 3 of 3
Thread: beam pocket
    Member Darius's Avatar
    May 6, 2013
    484
    05:39 PM
    beam pocket
    i found a very old thread on this so i created a W steel family with a beam pocket with some parameters
    question 1: i noticed the overall length parameter dissappears when i load this family into a project
    question 2: would i have to make every beam size with voids i notice if i load the W steel structural framing i dont get those sizes on the beam pocket family i created
    Attached Files Attached Files
    January 30, 2014
    CONNECTICUT, USA
    2
    03:39 PM
    Make void family and cut pocket, otherwise steel beam not get correct elevation because pocket above steel beam.
    May 6, 2013
    484
    05:39 PM
    elevation works just fine just adjust the beam pocket depth
    doing this for when u have to make alot of them the method u suggested is alot more time consuming when u have more than a couple
  1. Unable to create a Beam Pocket
    By alexo4141 in forum Structure - General Questions
    Last Post: May 23rd, 2019, 03:56 PM
  2. beam
    By khanhnamkts in forum Structure - General Questions
    Last Post: August 2nd, 2012, 11:08 AM
  3. High Beam Low Beam Tag
    By Alexander_J_Hicks in forum Structure - General Questions
    Last Post: July 25th, 2012, 07:20 PM
  4. Pocket-Door Family
    By jim jones in forum Architecture - Family Creation
    Last Post: November 7th, 2011, 12:27 AM
  5. pocket door will not cut base sweep
    Last Post: April 5th, 2011, 01:23 AM
