Results 1 to 5 of 5
Thread: Creating Drainage Plans in Revit
    March 21, 2014
    51
    02:02 PM
    Hi just wondering if anyone has had a go at this and could give me some help. I have currently created manholes using a structural column and then i can use the 'spot elevation' to tag my cover and invert levels. However i am stuck when trying to show the drainage flow direction on a pipe run as i am struggling to show an arrow symbol on my pipe in course detail. I know i can do this manually by creating a 2d region, however it would be great if i could show an arrow symbol which locates halfway down the pipe which shows the flow direction, i.e. start to end of pipe (note my pipes are created using the beam command).
    Any help would be much appreciated
    Thanks
    Craig L
    "OMG I killed Revit"
    dzatto's Avatar
    December 9, 2010
    5,234
    08:02 AM
    Welcome to RFo.
    Why not create your pipes using.....pipes? Then you can tag them to show flow.
    Well, I should add that's assuming you're using One Box. Which flavor of Revit are you using?
    Also, if you have to use a beam for a pipe, use the spot slope tool (annotate tab > spot slope). It will put in an arrow and a slope. Or, you could probably modify it to just show the arrow.
    March 21, 2014
    51
    02:02 PM
    Thanks dzatto,
    I have experimented with the MEP systems pipe and they work quite well. However where can i download a systems family of manholes and inspection chambers which enables pipes to snap to? i have tried sites such as revit city and autodesk seek, however i could not find any info on these???
    Member Darius's Avatar
    May 6, 2013
    481
    09:02 AM
    You would have to make the manholes your self to get a pipe to connect to it you just need to place a pipe connector in the family at the desired point of connection in the family
    Member l.schmidt's Avatar
    October 23, 2014
    Seattle, United States
    58
    03:02 PM
    Quote Originally Posted by craiglarkinmsj View Post
    Thanks dzatto,
    I have also looked around for some Revit manholes, but they don't really seem to exist. From what I can tell, very few people use Revit to model drainage- Civil 3D is still the preferred Autodesk program for that. As a result, there really isn't any manuf content out there yet.
    But you could certainly make one. I have messed around with the concept before, and it seems doable.
  1. Drainage fittings?
    By nick_h in forum MEP - Family Creation
    Last Post: December 19th, 2013, 07:47 PM
  2. Drainage Slope Feature
    By domsib in forum MEP - General
    Last Post: November 13th, 2013, 03:13 PM
  3. how to make floor drainage
    By jenniferli in forum Architecture and General Revit Questions
    Last Post: October 3rd, 2013, 06:32 PM
  4. Linking Callouts of Plans and Reflected Ceiling Plans
    By adamdr1 in forum Architecture and General Revit Questions
    Last Post: February 7th, 2013, 07:55 PM
  5. Drainage
    By stuhall in forum Structure - General Questions
    Last Post: October 9th, 2011, 07:23 AM
