Results 1 to 2 of 2
Thread: Creating a Helix Family
    February 19, 2014
    1
    06:23 PM
    Hey Guys,
    I am trying to model a helix family to represent a CFA for an auger cast pile drill rig. In the picture, the left side helix was made by creating semi-circle swept bends that is rotated & copied and pasted along a circular extrusion. This way works fine, but requires many steps in order to adjust each component.
    The right side is a circular extrusion with a void form to create the angled end cut. I then created a sweep bend that followed the path of the edges and copied and mirrored it to continue down the column. As you can see, the sweep bend is angled into the column and then fully merges into it. I am also not able to make the sweep bend profile any larger than the picture due to error's saying the sweep can't be created.
    Is there something I am doing incorrectly or is there another more efficient way to do this task? Or is there a way to rotate the profile of the swept bend to make it tangent to the column? Any feedback will be very helpful.
    Thanks!!!
    Attached Thumbnails Attached Thumbnails Creating a Helix Family-helix-picture.png
    Gold Coast
    2,602
    02:23 PM
    Quote Originally Posted by RoycePasalo View Post
    Hey Guys,
    Thanks!!!
    Errors in sweeps are usually from self-intersecting geometry ie, the profile is being asked to turn a corner that is too sharp, so the geometry hits up against itself, so of like a fat person trying to touch their toes
    If you haven't seen Alfredo Medina's tutorial yet have a look. I used this parametric array method to create 3D bolts and screws and so far it's proven bullet proof.
  1. Helix Sweep?
    By tzframpton in forum Architecture - Family Creation
    Last Post: August 28th, 2014, 09:24 AM
  2. Creating family - parameter that allows to set a number of elements
    By tomas92 in forum Architecture and General Revit Questions
    Last Post: November 14th, 2013, 02:44 AM
  3. Creating shutter family
    By boriskam1991 in forum Architecture and General Revit Questions
    Last Post: July 28th, 2013, 04:25 PM
  4. Creating a new door family from scratch
    By madu in forum Architecture - Family Creation
    Last Post: January 22nd, 2013, 06:04 PM
  5. Creating two key commands for a specific family
    By fire guy in forum MEP - General
    Last Post: November 30th, 2012, 11:46 PM
