Results 1 to 2 of 2
Like Tree1Likes
  • 1 Post By tlipiec
Thread: How to create fixed-length truss family?
    February 5, 2014
    1
    11:25 AM
    Question How to create fixed-length truss family?
    Hi folks,
    I am facing a minor problem, tried to look it up in quite a few places but with no luck. Just FYI: I'm relatively new to Revit (not completely newbie tho), so I'd really appreciate a bit more detailed answer, thanks! Ok, here's the problem:
    In my project I have one big truss (76m) that consists of three different 4m long segments arranged in a random order (that is still quite likely to change). I thought the best approach would be to create three families of 4m trusses and then load them into the main project and arrange in a desired order. The thing I cannot figure out is how to 'fix' the truss length so it won't change when 'drawing it' in the main project - so at the end of the day I would end up with a truss of a fixed height and length just with the possibility of changing top, bottom chords & web sections. I have alignment constrains on 'truss length' & 'truss height' dimensions (see pic. below). I know I can manually type in the desired length and eight when creating it, but I was wondering if there is another way. Thanks for your help!
    revituy likes this.
    July 4, 2013
    179
    04:25 AM
    I usually just create trusses like a generic model. Create the sketch in the front view and make sure its centered. They behave much better than the stock trusses.
  1. Need help to create a model with a repetitive customized truss
    By juancar373 in forum Structure - Family Creation
    Last Post: June 26th, 2013, 10:22 AM
  2. Truss Family
    By MartinGT in forum Structure - Family Creation
    Last Post: October 28th, 2011, 07:07 PM
  3. Replies: 0
    Last Post: October 13th, 2011, 10:16 PM
  4. help urgently needed... trying to create a 3D Truss (space frame) system.
    By sadabukon in forum Structure - General Questions
    Last Post: April 19th, 2011, 11:25 PM
  5. How to create 2d truss?
    By pjetrus in forum Architecture and General Revit Questions
    Last Post: April 2nd, 2011, 03:58 AM
