Results 1 to 5 of 5
Thread: Movable Label Annotation in a Detail Item Family
    Junior Member SamHenderson27's Avatar
    August 9, 2013
    Christchurch, New Zealand
    12
    10:43 PM
    Hi there,
    I am trying to create a detail item family where i can have a label annotation constrained to the center of the detail item but movable if need be.
    Almost exactly like the standard Revit dimension tool. I want to be able to drag the label around where i want.
    Attached are a couple of pictures to help understand what i mean.
    Any ideas?
    Many thanks,
    Sam
    Attached Thumbnails Attached Thumbnails Movable Label Annotation in a Detail Item Family-1.png   Movable Label Annotation in a Detail Item Family-2.png
    jmk
    jmk is offline
    Forum Addict jmk's Avatar
    December 31, 2012
    NM, USA
    1,415
    04:43 AM
    You can't make it dragable just like Revit's dimension tool, but you can get pretty close using a nested label and offset parameters. Make the label you want to be able to move as a separate generic annotation that is centered on its reference plane. Nest it into your detail item family and attach it to reference planes that are controlled by your offsets in whichever direction(s) you need.
    August 9, 2013
    12
    10:43 PM
    Thanks for your feedback jmk
    Member bogrady's Avatar
    November 20, 2013
    Victoria, BC CANADA
    132
    03:43 AM
    you could load your custom dimension arrow heads and create your own type of dimension, then override the dimension text by double clicking on the text to be what you want and it will work as you want... I think
    October 18, 2012
    3
    01:43 PM
    An addition to jmk post, you might also try not to nest the label but instead use a reference plan and group it with the label you want it to move. Now you can use the offset parameter to move the reference plane and it will move the label too since they are grouped.
  1. Movable Text in an Annotation Symbol
    By ThatBIMGuy in forum MEP - Family Creation
    Last Post: June 27th, 2017, 05:57 PM
  2. Replies: 0
    Last Post: January 29th, 2014, 02:15 AM
  3. Offset a Label with a Nested Annotation Symbol
    By domsib in forum MEP - Family Creation
    Last Post: November 29th, 2013, 11:01 AM
  4. Replies: 2
    Last Post: November 27th, 2012, 06:44 PM
  5. Replies: 0
    Last Post: October 27th, 2011, 08:15 AM
Tags for this Thread
