Results 1 to 9 of 9
Like Tree2Likes
  • 1 Post By TRWhitehead
  • 1 Post By Alex Cunningham
Thread: Dead Horse - Beating it
    Member TRWhitehead's Avatar
    February 16, 2012
    Portland, OR
    328
    05:52 AM
    So I was looking at our elevation symbol, we had been converting up from gawd knows how long ago, and decided it was a big ole mess.
    Here's our ACAD standard which is what mgmt wants me to match all the time.
    I got the elevation marker in no problem. Whittled down the family to just have one "view" or direction available, threw a parameter switch to allow the text to rotate properly and done. End result:
    Feeling good about this revelation I said, "Well hell, what if the section mark could work better?" So I tried.
    GAwd that was awful. I get why it does what it does and am a little bit in awe at the black box that accomplishes it. But seriously? It is awful for us. I get it might be more function for some folks but here's where I have problems.
    1) it is too big. you can't really get it down to something compact and useful.
    2) Why is that silly "rotate with component" parameter there (true with many categories) if it is useless?
    3) I hate having to tell folks "that is just the way revit is, you can't change that part" (paging Marcello!) but I just can't figure a way around this.
    If you put a hatch region in, it rotates. If you put lines in, mostly they rotate. But a label? doesn't rotate. What if I....? nope Rotate w/ component... hahahahahhah, nope.
    Anyway, does anyone have ideas? I'm open. I can post the elevation tag if for some crazy reason you haven't already figured this out for yourself (I always think I'm the last to figure stuff out)
    I'll be right over here:
    d.stairmand likes this.
    Alex Cunningham's Avatar
    December 8, 2010
    Northern California
    3,567
    05:52 AM
    Man this is the best post I've read in months. Koodos
    Please posts your section family for the masses to take a look at.
    snowyweston likes this.
    December 21, 2010
    C.LONDON
    4,353
    01:52 PM
    Quote Originally Posted by Alex Cunningham View Post
    I think I see what you did there.
    February 16, 2012
    Portland, OR
    328
    05:52 AM
    Really? Best post in months? Thanks but I don't see it, just a shot in the dark.
    Ok as requested. I'm posting both the elevation marker and what I played with. I really didn't get anywhere with the section head.
    Section mark is just different things I've tried. And here's some info on that via pictures:
    This does nothing as far as I can tell.
    This is what I mean by amazing mechanics. How does the "system" know which of these bits to rotate and which don't? How can I get a label (and a hatch region) to follow the line of the section? and not stay orthogonal (but readable) to the view.
    Maybe Santa will see this and give me a post Christmas present of the factory providing some insight.
    Attached Files Attached Files
    Member bogrady's Avatar
    November 20, 2013
    Victoria, BC CANADA
    132
    05:52 AM
    Controlling Label Locations
    I have also been throttling a deceased quadruped. I have been working on controlling the location of text and labels. I have been able to make a label auto-center in geometry by making it a nested family of a label with two reference planes defining its origin. The label location can then be controlled through dimension parameters in the parent family. I used this to auto center titles in 'Detail Boxes' for our typical details. I will attach the families. I have not attempted rotational controls however. All I know about rotation is that you need to use reference lines rather than planes as planes have 'no ends' and will go wacky in certain situations.
    My main conundrum is getting the nested label in the 'Typical Detail Box' to 'Read' the parameters of what sheet the host Detail View is placed on. Does any one know if this is the direction to go or how to do that? or should I start another thread.
    March 25, 2014
    3
    04:52 AM
    I'm struggling with the exact same issue as Tom. Has anyone come up with anything yet?
    February 16, 2012
    Portland, OR
    328
    05:52 AM
    Scott,
    With regards to a section mark that is compact and more like what a lot of structural firms are used to? No. No dice so far.
    March 31, 2014
    4
    12:52 PM
    AAAAAAAAAAAAAAAAAAAAAA!
    I have two questions:
    1. Why hasn't Autodesk worked this out by now?
    2. Why do I insist in continuing to try and make this work when I know, deep down, that I have tried everything?...
    Well, anyway... I guess I'll give up for the day. Or maybe...
    December 21, 2010
    Phoenix, AZ
    2,556
    05:52 AM
    whisper word of wisdom, let it be, let it be, let it be
  1. Who Says the Art of Proof Reading is Dead!
    By Ian.Kidston in forum Out There
    Last Post: July 25th, 2012, 08:55 PM
  2. dead in the water again: door opening visibility
    By lost again again in forum Architecture - Family Creation
    Last Post: May 8th, 2012, 08:59 PM
  3. DEAD? please explain...
    By revit-mcs2011 in forum MEP - General
    Last Post: June 24th, 2011, 10:18 PM
  4. Dead Levels
    By redmonki in forum Architecture and General Revit Questions
    Last Post: March 28th, 2011, 12:57 PM
