Results 1 to 2 of 2
Thread: Structural Framing export to CNC
    December 16, 2013
    2
    04:20 AM
    Hi there.
    I want to cut at a CNC machine some parametric boxes from plywood.
    I need to have a family with the boxes and some version of it with different sizes (around 35).
    So I planned to have a family and make some sections views where I would isolate every piece of plywood and after that when I put all of them in a model I will make probably a script that will export every sections from the families in a dwg for CNC cutting.
    My problem is that I can not make an isolation of faces permanently. I was thinking about using Assembly views but it will be a little hard to create for 35 boxes.
    Please let me know if you think is some other way i could do this.
    Thanks a lot!
    January 17, 2011
    1,982
    11:20 PM
    Setting up Views for each "side" and using Element Hide isn't enough? Am I missing something? It seems that would work.
  1. Structural framing alignments
    By Linear_z in forum Architecture and General Revit Questions
    Last Post: July 2nd, 2013, 02:56 PM
  2. Structural Framing
    By DD1 in forum Structure - General Questions
    Last Post: June 15th, 2012, 06:52 PM
  3. Structural Steel Framing
    By asanda in forum Structure - Family Creation
    Last Post: March 9th, 2012, 04:11 PM
  4. structural framing tag
    By r7_human8y in forum Architecture and General Revit Questions
    Last Post: December 6th, 2011, 06:59 PM
