Results 1 to 2 of 2
Thread: shared family and <family type.....> parameter, when loaded error
    Member Bross's Avatar
    June 16, 2011
    The Netherlands
    138
    03:49 PM
    Hi There,
    i want to make a family were i nest a structural framing family as an shared host family.
    Everything goes ok, even when i load the family and change the host type in edit type.
    Only when i copy the family with its host family in it i wil get an warning,"Elements were deleted".
    End result, i've copied the family and nothing seems to be deleted.
    So i could say, ignore the warning and go on with it.
    Only thing, it bothers me when i get a warning and i dont know what it is.
    Plus i want to know what happend, and where it went wrong.
    anybody any ideas?
    shared family and &lt;family type.....&gt; parameter, when loaded error-bross_prob_revit.png
    Attached Files Attached Files
    June 16, 2011
    The Netherlands
    138
    03:49 PM
    simple test
    now i've tested it out with a more basic simple family.
    I've made a parrent = orange line based.
    a child A = green and line based
    a child B = pink and not line based.
    It seems, when only nest child B the wil not be such a warning.
    So two line base families nested in each other is causing the trouble.
    For now, i dont know why revit does not like it, but my solution now is clear.
    I wil make my "childeren" the nested structural framing a non line base family.
    Back to where i've once strarted that is.
    shared family and &lt;family type.....&gt; parameter, when loaded error-bross_prob_revit_test.png
  1. Can I Use Family Type Parameter in Conditonal Formula?
    By cordell in forum Structure - Family Creation
    Last Post: November 26th, 2014, 12:57 PM
  2. Type Catalog to family parameter
    By alex60 in forum Architecture and General Revit Questions
    Last Post: June 11th, 2013, 02:48 PM
  3. select by parameter? curtain wall panels' materials by parameter, by type or family?
    By oompa_l in forum Architecture and General Revit Questions
    Last Post: January 24th, 2013, 02:20 PM
  4. Using "Family Type" Parameter as a Shared Parameter
    By jmwatson84 in forum Architecture - Family Creation
    Last Post: May 8th, 2012, 09:36 PM
  5. Can you use a 'Family Tpe' parameter in a type catalogue?
    By brett05 in forum Architecture - Family Creation
    Last Post: September 6th, 2011, 06:45 AM
