twice now I've ran a rendering, walked away, it finishes but I can't do anything. I'm sure a dialog box is open somewhere but I can't see it or click it, so I'm stuck and have to close revit. Any ideas?
MONUMETRIC Video mmt-volt
Revit 2017.2 Rendering finishes but I cant close the dialog box
Scott D. Brown, AIA | Senior Project Manager | Beck GroupTags: None -
does alt+tab take you to the rogue window?Comment
Whenever a dialog box disappears to the point I can't access the main Revit interface to save or close it, I just try to sign out (or shutdown) Windows. By doing that, Windows will pop up a message saying that other software are still open and offer you to hit cancel to cancel the sign out or shutdown. Usually that triggers all "hidden" dialog boxes to pop up too allowing you to get back to work.
Be aware that if the Revit file was fully saved just before this happens there's no need for Windows pop up a message saying that you have open and unsaved files and therefore it will just sign out or shutdown without bringing the hidden dialog boxes. But then, hey, it was all saved regardless.Andre CarvalhoComment
Hello,
I'm running Revit on Windows 7 on a partitioned iMac with Intel Core2 duo processor. However, it only renders with one box at a time....-
Channel: Rendering and Gallery
Ok, it should be easy. recessed lights OOTB. I set artitifial lights in the rendering box, set to medium, default exposure.
In paul Aubins he loads... -
I'm having some major rendering problems in Revit (2012). Rendering a draft view takes a little over 4 hours. Rendering with artificial lights on, puts...
I have a friend with a very stout computer he uses as a server and rendering. The basic specs are as follows:
- Dual Xeon 5675's
- 96GB RAM (6x16GB
Channel: Hardware and Infrastructure
We've been using revit to make quick renderings of projects which works fine. We now need a high resolution rendering to be used on a construction site...
MONUMETRIC Anchor B sticky footer - 7ba6
