Hi everybody!
I’ve recently installed Revit 2017 and since then I’m having a very particular problem. Whenever I export to PDF the first time it works perfectly, but the second time it freezes somehow (you can see this in the JPG I’ve uploaded here).
It only resolves by restarting the program, which is quite a drag when I have to export several plans to PDF.
Is this a common RV 2017 issue?
Thanks a lot
Thanks a lot
