Hello,
I just started using revit; and I have a (big) problem. The project is almost finished, and I want to plot it.
First I wanted to export it to DWG, and plot it with autocad. BUT ALL THE COLORS CHANGE.
The Layers are not really a problem, but also the colors of regions I made are changed. I lose a lot of time by changing them again!
Then I installed PDF creator, so I can make a PDF in Revit. But there is a problem with the scale.
Everything needs to be scale 1:50 but how??
Hope someone can help me! Running out of time..
Thanks a lot!
Thanks a lot!
