Page 1 of 3 123 LastLast
Results 1 to 10 of 30
Thread: Interior elevations and elevation callouts
    January 27, 2011
    KC,MO
    346
    12:13 AM
    So I've figured out that it's best to turn off all of my levels in my interior elevations and just use spot elevations to callout my heights...however is there a way to adjust the endline of the tags so that I don't have lines running all across my drawing (see area in red).
    I tried originally doing it all with levels, but that's obviously a mess and gives me a million unnecessary levels throughout my project.
    Or, is there a better way to do it?
    "OMG I killed Revit"
    dzatto's Avatar
    5,245
    10:13 PM
    For what you are doing, I would use spot elevations.
    I don't think those lines are part of your tags. They look like a cut with a hatch associated to it. What does it say when you hover over it? If it's a section of an adjacent wall or something like that you can either hide the element in the view, or overide the visiblity graphics and turn off the cut hatch.
    January 27, 2011
    KC,MO
    346
    12:13 AM
    Sorry, not the wall hatch, I'm referring to where the spot elevation endpoint touches the object it is calling out. Is there a way to offset the end of the elevation tag so that there is a gap between the object and the end of the elevation tag?
    dzatto's Avatar
    5,245
    10:13 PM
    Oh, okay. I misunderstood. It happens a lot. lol
    Yeah, select the elevation symbol and go to the ribbon and hit the edit family button. I'm doing this off memory, but there should be 2 reference planes. The intersection is where it the insertiion point for the family is. Just back the line off of the insertion point and that should do it.
    If you want to take it a step further, you can add an instance (or type) parameter so you can adjust the gap manually.
    January 27, 2011
    KC,MO
    346
    12:13 AM
    I don't appear to be able to edit the spot elevation, as it's a system family.
    I can edit the symbol, which is the crosshair, but that doesn't seem to help.
    January 27, 2011
    KC,MO
    346
    12:13 AM
    Also, it would be nice if the heads snapped to align like the level heads did.
    dzatto's Avatar
    5,245
    10:13 PM
    Quote Originally Posted by stl4310 View Post
    Hmm, maybe I mispoke. This one is above my pay grade. Anyone else care to help??
    Kingdom of Denmark
    4,266
    05:13 AM
    Guess you could change the leader color to white (so it wont print) and then add a fixed line to the symbol.
    The invisible (white) leader will probably go on top of the fixed line in the symbol, so you might want to draw that just a little off the ref. plane in the symbol family.
    Not the best workaround in the history of Revit, but it just might work and I cant think of anything else...
    Yes, that would be nice indeed, but I dont believe that its possible - Sorry.
    Kingdom of Denmark
    4,266
    05:13 AM
    Just thought of another option.
    1. Open the symbol family, move the entire symbol to the left
    2. Draw a line from the symbol to the intersection of the ref. planes
    3. Load it back to the project
    4. In the spot elevation (system) family, set a negative offset for the text placement
    5. Turn off the leader and shoulder
    If it works (havnt tested) youd need to create both a left and a right spot elevation though...
    Kingdom of Denmark
    4,266
    05:13 AM
    Just did a quick test, and it works! But you do need to create both a "left" and a "right" elevation.
  1. interior elevation tags missing
    Last Post: August 30th, 2012, 06:42 PM
  2. Interior Elevation Properties
    Last Post: May 2nd, 2011, 02:27 PM
  3. Interior elevation irregular views
    Last Post: April 26th, 2011, 11:55 PM
  4. Interior Elevation Tag
    Last Post: March 3rd, 2011, 10:00 PM
  5. Select type of sections to turn off in interior elevations
    By Wadeshuey in forum Architecture and General Revit Questions
    Last Post: February 15th, 2011, 04:38 PM
