Thread: Butt-glazed corners
    January 27, 2011
    KC,MO
    346
    03:10 PM
    Butt-glazed corners
    What's the best way to model a mullion-less curtain wall corner? Where I have two pieces of glass that are butt-glazed?
    6,389
    03:10 PM
    You can swap in a custom wall type or create a small mullion to fill in the gap.
    Revit OpEd: Curtain Wall - Corner Butt Glazing Condition
    http://www.revitforum.org/architectu...t-joining.html
    11,023
    02:10 PM
    We use seperate families for all of the Curtain Wall conditions, since the corner mullions in revit leave much to be desired. So we disallow join, delete the corner and end mullions, place the families, and drag the handles to the correct spot. We have a corner with snap cap, a chevron, a canted piece, an inner corner, etc, and they have parameters similar to the ones in our mullion profiles, so people dont get conufsed when editing the sizes.
    December 20, 2010
    1,126
    03:10 PM
    I use a column family that is the shape of the mullion I want at the corner. I put the geometery on a sub-category so I can control its lineweight diff. from other columns. I typically use a modified panel at the corners that has an instance parameter for the overhang of the gridline so I can get it to come to a corner the way I want.
  1. Bifold Glazed Door
    Last Post: August 7th, 2012, 01:17 AM
  2. edit wall corners
    Last Post: March 30th, 2012, 02:18 AM
  3. finding elevation reading at building corners
    By joss in forum Architecture and General Revit Questions
    Last Post: February 13th, 2012, 06:38 AM
  4. Revit Kid: Curtain Wall Corners
    Last Post: December 29th, 2011, 01:15 PM
  5. Building Coder: Pick Corners and Create Floor
    Last Post: November 9th, 2011, 09:15 AM
