Thread: design options
    2,645
    01:13 AM
    design options
    I'm working on a 2 box modular building where I would like a 3rd box to be a design option (on or off). I have created a single option containing the 3rd box and the first 2 boxes are still in the 'main model'. When I go to VV I only have the ability to 'show only' the 3 box option without the primary model. No way to 'show only' the main model, without the 3rd box.
    My question is, should I have the primary 2 box construction (definately being built) in it's own Design option?
    "OMG I killed Revit"
    dzatto's Avatar
    5,234
    10:13 AM
    You lost me at VV... Did you mean VG?
    When you create a design option, they are view specific. Once you create one, there will now be a Design Option tab in your visibility graphics (VG). You'll need to create a new view, then set the DO in the DO tab to whatever you want to show. I hope that helps.
    July 20, 2011
    854
    08:13 AM
    i always create an empty design option as one of the design options for each design option set, very useful for VG control & checking purpose, hope it helps.
    Auckland, New Zealand
    611
    03:13 AM
    This value fights with the parameter in view properties 'Visible in Option', which allows testing of individual options, rather that combinations of. and can override the VG option.... grrrrr
    To set this up properly, as Ning Zhou suggests add a second option to the option set that doesn't have your 3rd box.
    If you want the 3rd box off by default, set this second option as 'Primary'.
    To control visibility
    1. as above, use 'VG'>'DO' tab for that view.
    2. Use the 'Visible in Option' property in 'View Properties'
    Peace...
    2,645
    01:13 AM
    yes, sorry VV=VG. Type VV and see what happens
    Quote Originally Posted by Ning Zhou View Post
    This seemingly works for visibility only? I need to work in the design option, but a good tip.
    **edit- this works a treat...of course the facade wall from my 2 box build goes into its own DO
    Quote Originally Posted by Tim West View Post
    Peace...
    This was much appreciated advice you mentioned to me in another thread awhile back, thanks mate
    So the answer to my OP is 'yes' thanks guys!
    dzatto's Avatar
    5,234
    10:13 AM
    Damn, I had no idea VV opened VG. That's even easier!
  1. Printing Design Options?
    By lieblick in forum Architecture and General Revit Questions
    Last Post: July 17th, 2012, 05:53 PM
  2. Design Options
    Last Post: January 30th, 2012, 03:23 PM
  3. Demolition and Design Options
    Last Post: May 24th, 2011, 04:58 PM
  4. Design Options
    Last Post: May 4th, 2011, 01:24 PM
  5. Design options and constraints
    By jbenoit44 in forum Architecture and General Revit Questions
    Last Post: April 12th, 2011, 11:33 AM
