Thread: Graphics Cards from the Factory
    Moderator mark b's Avatar
    NSW Australia
    1,436
    01:23 AM
    Good little blog on Graphics Cards and Revit, from Inside the Factory.
    I don't care how much that card is I just have to have one. It looks so cool !!
    Rotterdam, South Holland
    3,071
    04:23 PM
    Just thought I would post out of character and note that this Inside the Factory post is a direct response to a question I had for the Factory elsewhere all of a month or so ago. So credit where credit is most certainly due. Thanks Erik; for good info, and good info made public in a very timely way.
    Gordon
    03:23 PM
    Gordon
    Nice of you to mention this, especially considering your ranting here.
    3,071
    04:23 PM
    Just trying to be balanced. Sometimes Autodesk chaps my hide. Sometimes they balm my hide. In neither case are they actually concerned about my hide, but I tend to bring it up anyway. Both ways. Or at least try.
    Gordon
    Alex Cunningham's Avatar
    Northern California
    3,576
    08:23 AM
    Far to much talking about your hide in this post. LOL
    February 11, 2011
    the Netherlands
    52
    04:23 PM
    Correct me if i'm wrong but the post from "inside the factory" does it only applies to the realistic view or also the other visual styles?
    3,071
    04:23 PM
    Only Realistic views involve textures, so only Realistic views use Graphics RAM in this way. Other views will be impacted by graphics card performance if shadows and/or ambient occlusion is turned on, but only Realistic views will use the RAM.
    It should also be noted that Windows 7 also uses graphics RAM to store application windows. The card holds the entire app window, not just the exposed part, and all the app windows are then composited on the screen (just like the Mac circa 2002 ) The net result is that when you move windows around on screen, and the underlying app is too busy to update its window, instead of blank white areas you see the newly exposed area of app window, based on the last update.
    And lastly, 64 bit Windows, be it Windows 7 or (shudder) Vista, map Graphics RAM differently, so there is not a down side to more graphics RAM like in 32 bit Windows.
    What does it all mean from a use perspective? If you are running 64 bit Windows 7, you can buy a graphics card with the performance you need, and rather than causing problems and not getting used, the graphics RAM will actually now be of benefit. The more you have, the more open application windows you can have, and also the more you can use Realistic Views and not see a performance hit.
    I don't think more than 1-1.5 GB of graphics RAM is ever really going to get used this way. Unless you have 100 open app windows and Realistic views with hundreds of different textures. But at least it isn't the bad old days where the only fast cards had 512 MB + of RAM and actually caused problems for Revit users, while 100% of that RAM also went wasted.
    Gordon
  1. Revit Hardware : Video Graphic Cards
    By iru69 in forum Hardware and Infrastructure
    Last Post: May 22nd, 2020, 09:18 AM
  2. Framing Plan/ Visibility Graphics
    By iitdesigner in forum Architecture and General Revit Questions
    Last Post: April 18th, 2011, 01:15 PM
  3. Graphics Issue
    Last Post: April 14th, 2011, 08:17 PM
  4. From Inside the Factory
    By mark b in forum Out There
    Last Post: February 13th, 2011, 11:48 PM
  5. Showing tags and/or graphics in schedule fields
    By archlight52 in forum Architecture and General Revit Questions
    Last Post: December 13th, 2010, 03:46 AM
