Thread: Shared Parameters
    June 11, 2012
    Portsmouth
    55
    01:17 AM
    Shared Parameters
    Hello. New to forum
    I am creating a composite timber structure using Revit Structure and I want to share the thickness of a sheet of ply with three independant families. I am able to include the shared parameter with each family but I have to set the value in each model.
    Is there a way of setting the thickness of the ply as a default. I change the thickness of the ply in one file (preferably in the project drawing) and the thickness changes in the other models?
    Regards
    6,205
    08:17 PM
    I don't believe that is possible without selecting the family and entering the parameter. You might be able to push it using some of the Whitefeet tools but in this particular case I don't know if it's worth it.
    Kingdom of Denmark
    4,236
    02:17 AM
    Create the Ply as a separate family, nest it into the composite timber families as shared. Update one instance of the Ply when loaded into the project, and the other instances will update too.
    June 11, 2012
    Portsmouth
    55
    01:17 AM
    Cheers
    Will give it a go
  1. Shared Parameters - need assistance
    Last Post: March 7th, 2012, 07:32 PM
  2. Shared parameters Issues
    By JCM in forum Architecture and General Revit Questions
    Last Post: December 20th, 2011, 09:50 PM
  3. Shared Parameters
    By Ali Akbar in forum Structure - General Questions
    Last Post: April 26th, 2011, 08:19 AM
  4. family and shared parameters
    By jbenoit44 in forum Architecture - Family Creation
    Last Post: March 2nd, 2011, 12:24 PM
