MONUMETRIC Video mmt-volt
Joined walls and Doors- doors with different expected width
Tags: None
Add a few reference planes on either side of the wall in the door family. Create a few parameters so you can adjust the offset. Attach the depth of the door frame to those reference lines. This way, you can adjust it in the project for different wall thicknesses.Dan -
it would be much more easier if revit doors understand joined walls as a single wall... There should be a parameter "joined hosts" (yes or no or a label)... We have to modify a lot of families to this... I thought about this solution but I was hopping there was a better solution. This one is not a good one. :/Comment
They recognize a joined wall as far as the opening goes. What the OP is referring to is the door frame. It will only take on the width of the host wall, as far as I know. The only fix is to create your door families with a set of parameters to take any width joined walls into account.DanComment
I'm not following this...Martijn de Riet
Professional Revit Consultant | Revit API Developer
MdR Advies
Planta1 Revit Online ConsultingComment
Yes, it is a better idea. Attach base and join solvs a lot of problems.
But to get quantities with a bigger precision is better to use separeted walls. But there is a lot of problems with that, this one is just one. :/
I waste too much time with this "solution", and I'm realizing that's not the better one. Roombook help us to take quantities in a better way.Comment
I wondering if there is a door family out there or to show me how to build a door family that locates the door in the correct location of the wall? right...
Hi Guys, I am coming with another problem. My Doors are not cutting the walls on certain places. I played with view range but still the same issue....
I want to start my first door family but need some guidance.
i would like existing doors to have the 45 degree swing. I assume i would...-
Channel: Architecture - Family Creation
Hi, does anyone know if there is a timber sliding door in the revit library, or any sliding door that slides on the outside skin of the wall, unlike the...
I have a 2x6 wall with 4" stone.
When I put a window or door on it, it goes flush with the stone.
How do I make the windows and doors...
MONUMETRIC Anchor B sticky footer - 7ba6
