Page 1 of 3 123 LastLast
Results 1 to 10 of 24
Thread: Wall Clean Up Problem
    January 24, 2012
    23
    01:03 AM
    I have a wall cleanup problem I hope to get help with. I want a single leaf blockwork wall to clean up with a cavity wall's interior blockwork. The Cavity wall comprises of the following layers: 102.5mm Brickwork exterior leaf, 35mm Air Flow, 65mm Insulation, 100mm Concrete blockwork interior leaf, 25mm Timber Battons, 12.5mm Plasterboard. There is a Sweep with a Buttress profile to the base of the Exterior.
    The single leaf Blockwork Wall doesn't cleanup with the Cavity Wall's Interior leaf Concrete Blockwork. There should be a clean 'T' join however lines appear where the join is. A work around was to creat a seperate wall for the Timber stud and plasterboard and join the two walls but this is time consuming and the reveals on ope's aren't included.
    Please see attached image and a copy of the RVT file.
    Thanks,
    Peter
Name:	Wall Clean1.JPG
    Moderator gaby424's Avatar
    December 11, 2010
    912
    03:03 AM
    because one wall has that layer in the core boundry and the other out of the core boundry.
    Revit doesn`t like that..
    "OMG I killed Revit"
    dzatto's Avatar
    5,273
    08:03 PM
    Exactly. I was bored so I fixed it for ya. Is this the look you are going for?
Name:	Wall Cleanup.JPG
    January 24, 2012
    23
    01:03 AM
    The layers inside the Core Boundary are Insulation and an air Flow, if I move the Insulation layer outside the Core Boundary the problem gets worse because the Single leaf Blockwork Wall extends further inside the Core Boundary.Click image for larger version.
Name:	Wall Clean2.JPG
    dzatto's Avatar
    5,273
    08:03 PM
    I always put the structure inside the core boundary (if there is a structure layer, that is). Then build the wall out from there. Substrate, thermal, finish.
    One of your walls had the CMU in the core boundary, one wall had the CMU out side of it.
    Also, you need to label the functions properly. CMU should be your structure, not substrate. The function determines what goes through what.
    January 24, 2012
    23
    01:03 AM
    Thanks, I achieved that before but it is still incorrect because the now the inner leaf Blockwork isn't wrapping which is very important and it has to be outside the Core Boundary to wrap.
    dzatto's Avatar
    5,273
    08:03 PM
    You lost me on that one. If you have 2 block walls, how does the brick work wrap it? The two block walls are the structure, everything else is just facade.
    EDIT** are you talking about it wrapping around the openings?
    January 24, 2012
    23
    01:03 AM
    The Inner leaf in Irish Construction Closes the cavity, please see attached image for exact detail.Click image for larger version.
Name:	Closing Cavity Detail.JPG
ID:	7769. I use the Wall Closure Paramater in a Door or Window to determine how far teh block will wrap so I can leave a gap for Cold Bridging Insulation.
    January 24, 2012
    23
    01:03 AM
    Yes, openings/inserts and at ends.
    dzatto's Avatar
    5,273
    08:03 PM
    Is that really how it's done? I'm not being negative, I've just never seen that before. Why wouldn't you wrap the exterior brick to close the cavity?
    Anyway, back to the topic at hand. Let me mess around with it and see if I can get it to work. I'm guessing I won't be able to, but I'll try again now that I understand the issue. You're right, you can't wrap a core layer.
  1. Stacked wall clean-up issue
    Last Post: January 26th, 2015, 04:24 PM
    Last Post: April 9th, 2012, 11:45 PM
  3. Identifying wall buildups problem
    By maskelllee in forum Architecture and General Revit Questions
    Last Post: March 14th, 2012, 06:04 PM
  4. What Revit Wants: Clean up your DWGs before Linking them
    Last Post: January 12th, 2012, 10:15 PM
  5. Clean up Duplicates
    By DaveP in forum Third party Add-Ins, API and R&D
    Last Post: May 4th, 2011, 02:25 PM
