Thread: creating semi-open walls and doors
    Junior Member mno's Avatar
    April 12, 2011
    Amsterdam, the Netherlands
    30
    11:02 AM
    Hi, I want to make a brick wall that is semi-open, see attached photo.
    I've tried to dot this with 'edit profile' but copy-pasting this wall takes forever and with ever wall (4m wide / 3meters high) my file grows with megabytes at a time.
    I've got the tip to use a wall-reveal, but that's continuous right?
    And the same question for a garage-door (and meshed fences etc.) that is more open than closed. (see second attached file)
    I might have to try this as a curtain-wall panel? Is that the way to go?
    Ofcourse it's just for the 3D, in elevation-view I can create a pattern to represent this.
    Thanks!
ID:	7245   Click image for larger version.
    4,442
    10:02 AM
    Quote Originally Posted by mno View Post
    If you look for the recent thread on how to do a metal grate facade you'll find most will advocate a surface hatch pattern and a material with a bump for renders - there's already a brick one in the default materials library like that (IIIRC) - so all you need do is model a different wall type for the seperated bond area and either embed it within the main wall, or compose it within a stacked wall.
    Othewise, if you're 100% set on it modelled, look for the bitmap plugin (discussed at length on Buildz) to the bricks as curtain panels.
    April 12, 2011
    30
    11:02 AM
    Thanks, we'll render it in 3D-VIZ anyway, so a surface hatch-pattern will do just fine!
    Kingdom of Denmark
    4,276
    11:02 AM
    For the bricks to render just remotely correct in 3D max, I'd forget about the system tools (walls, curtain walls, etc.), and instead create 2 families...
    1 for below the windows, and 1 to go between the windows... Copy/Mirror those two as needed, and you'll still have a great performance.
    And yes, in the family editor, I'd model every single brick, and even the joints
    PS. The garage door should render fine with a standard mesh material... No need to model that.
    Wellington, New Zealand
    729
    09:02 PM
    Hi, I want to make a brick wall that is semi-open, see attached photo.....!
    We have done exactly what that photo shows (ie" Brick screen) by creating a wallbased family which is just a brick sized void and then copying around
    April 12, 2011
    30
    11:02 AM
    Thanks Alex. I actually did that last Friday! I've created a window family with 2 columns of voids that stretch from level to level.
    I've arrayed those voids and made them parametrical. If I load that family in my project and place it in a wall I can enter the number of columns.
    So with one family I can create an open-brick-wall of 1 meter wide of 10 meters wide.
    It takes a lot of time to load, but after that, the performance of the project doesn't decrease..
  1. wall opening (and/or un-unjoinable walls) creating problem: please help!
    Last Post: May 22nd, 2012, 02:56 PM
  2. Windows and Doors on walls question.
    By wjnaim in forum Architecture and General Revit Questions
    Last Post: September 21st, 2011, 01:50 AM
  3. Room shading is blocking walls and doors
    By BrianHed in forum Architecture and General Revit Questions
    Last Post: August 3rd, 2011, 12:17 PM
  4. Creating Detailed windows and Doors
    By dlggnation in forum Architecture - Family Creation
    Last Post: June 28th, 2011, 02:48 AM
  5. Custom/Standard Doors in Curtain Walls?
    By NLG in forum Architecture - Family Creation
    Last Post: April 12th, 2011, 06:39 PM
