Thread: Object display in existing phase
    6,389
    05:01 PM
    In my typical ADA toilet & grab bar family I have the ADA clearances sketched in with detail lines so they show up on plans to keep everyone happy - all fine and good in new construction. When I switch the toilet over to an existing phase the ADA lines show up as a solid line, rather than the dashed line that it should be. Other than an instance paramater is there a way to configure the family to either keep the lines shown dashed or hide them completely in an existing phase? I briefly toyed with an override in VG but the phase override seems to take precedence.
    11,040
    04:01 PM
    Tell your Phase override to only override color and lineweight, and not linestyle, and it should be fine...
    February 5, 2014
    7
    02:01 PM
    Thanks
    I was having the same issue. Thank you for posting this.
  1. Request rights to a object
    By mickiolin in forum Worksharing, Revit Server & C4R
    Last Post: March 16th, 2012, 02:48 PM
  2. Phases - Existing/Phase 1/Phase 2 - Braced Frame Elevations and such
    Last Post: November 11th, 2011, 12:57 PM
  3. any way to have existing phase show materiality?
    Last Post: September 9th, 2011, 03:39 PM
  4. Help with phasing - object outlines in wrong phase
    By paddyjoy in forum Architecture and General Revit Questions
    Last Post: August 4th, 2011, 11:03 PM
  5. An object repository
    By cganiere in forum Architecture - Family Creation
    Last Post: February 22nd, 2011, 10:23 AM
