Results 1 to 10 of 10
Thread: Existing Curtain Wall w/ New Panels
    Member Chadwick17's Avatar
    Fort Collins, CO
    325
    07:19 PM
    Working on a project where the existing curtain wall is to remain but the doors in it are being relocated to different spots in the same curtain wall. I've noticed that the curtain wall panels are tied to the curtain wall's phasing. How does everyone else handle the demolition and replacement of new panels in an existing curtain wall?
    01:19 AM
    I have never tried this, but you might want to try this:
    1. Unlock the affected panels.
    2. If you don't have it already: create a curtain wall type with no border mullions or subdivision applied. Basically an empty family with a panel type applied.
    3. Replace the affected panels with this curtain wall type. You now have a CW inside a CW which you should be able to demo (?) and replace with another CW in the new phase. Might work, but I think not (don't have Revit here to check)
    If that doesn't work: use a dummy wall for a panel. Host a custom made door/window family (to match panel layout) and demolish that. Then replace with new.
    Fort Collins, CO
    325
    07:19 PM
    Great suggestion. I ended up using the dummy wall for the existing panels to be demo'd and the new ones to replace them. Tedious, but gets the job done.
    Your first suggestion didn't work since anything that is hosted inside that existing curtain wall will have the same phasing.
    Thanks for the help!
    01:19 AM
    Yeah, I thought so. But it was worth a try. Glad to be of service!
    Autodesk JeffH's Avatar
    807
    09:19 PM
    I actually just added a video form Paul Aubin on this subject to the wikihelp.
    Curtain Wall Demolition - WikiHelp
    Fort Collins, CO
    325
    07:19 PM
    Jeff - that video is exactly what I did following Martijn's advice. Thanks for posting that - will be a lot more easier to explain to the rest of the office.
    01:19 AM
    Quote Originally Posted by Chadwick17 View Post
    I know, I explained it to him...
    (no, not really...)
    807
    09:19 PM
    Glad that makes it easier to explain to your co-workers. Now that it is at the wiki, maybe other Revit users will have a better chance of finding the answer as well.
    Fort Collins, CO
    325
    07:19 PM
    Here's a new wrinkle - all panels along a 200' span at the ground level are going to be replaced with spandrel panel. The thought of going through this same process for 30 different panels (along a curve) is giving me a slight headache... it seems, as already discussed here, that there really isn't any other way though.
    01:19 AM
    Yeah, that's a pain... That's why god invented interns I guess...
    You could split up the CW and replace it as a whole, but that would mean the Mullions would show up in your schedule too. Only way around that is putting in a SP for filtering your schedules.
  1. Curtain wall - Solar Protection Panels
    By p.j in forum Architecture - Conceptual Massing and Adaptive Components
    Last Post: February 12th, 2018, 09:03 PM
  2. Wall Tags for wall panels - Display in plan and elevation
    By JasonWallis in forum Architecture and General Revit Questions
    Last Post: January 30th, 2012, 06:45 PM
  3. custom curtain wall creation (mullion profiles, panels)
    By tweg in forum Architecture - Family Creation
    Last Post: July 20th, 2011, 02:11 PM
  4. Custom Curtain Wall Panels and Mullions:
    Last Post: June 9th, 2011, 04:26 PM
  5. Custom Curtain Panels
    Last Post: January 9th, 2011, 02:09 PM
