Results 1 to 10 of 10
Thread: Shared YES/NO Parameter Visiblity Problem
    October 14, 2011
    21
    10:59 PM
    Hello everyone, I am stuck trying to use a yes/no shared parameter to display text in a tag. What I am trying to accomplish is the following: I have a footing family which I have a Yes/No shared parameter setup in. I would like to pass this yes/no parameter into an associated footing tag which would then control the display of the text in the tag family. Essentially all I am looking to do is add an asterisks (*) to the end of the footing callout. I have added a label to the tag family which correctly grabs the yes/parameter from the associated footing however I can only get the label to display "YES" or "NO" when the box is checked/unchecked.
    Where I am really getting stuck is trying to setup another text parameter which will change the shared yes/no parameter entry from the footing family into text. I have read similar posts to this, but they only address how to accomplish this in schedules where you can set up a calculated parameter which would return the correct text needed.
    Does anyone have any ideas on how to accomplish this? Am I missing somethings really simple?
    Thanks for the advice.
    Alex Cunningham's Avatar
    Northern California
    3,572
    10:59 PM
    Can you share the tag and the footing family so I can get a better idea of how you are controlling eveything.
    I am pretty sure I can get it to work the way you are asking.
    October 14, 2011
    21
    10:59 PM
    RE:
    Alex, here are some screenshots of how I have things setup. Hope this helps, and thank you for your help!
    August 2, 2011
    150
    01:59 PM
    Hi, in that case,
    I reckon that it's similar to mine.
    Though mine is more related to Title block , I hope this may help you.
    http://www.revitforum.org/structure-...-editable.html
    Northern California
    3,572
    10:59 PM
    Quote Originally Posted by RPU_Eric View Post
    So you want a visibility paramter to be shared between your foundation and tag. Select the foundation and turn on T&B and have your tag change?
    Change your SP of T&B Reinf to a text paramter and add it to the end of your tag lable.
    http://screencast.com/t/UP5E0wuH9QY0
    http://screencast.com/t/dnSGEt9cyks
    To the best of my knowledge you can not use a yes/no paramter outside of the title block families.
    October 14, 2011
    21
    10:59 PM
    RE:
    2012-02-14_0816 - Alex_Cunningham's library
    2012-02-14_0817 - Alex_Cunningham's library
    Thanks Alex, that is what I was afraid of. I really wanted to try and keep the T&B Reinf SP as a Yes/No option but it seems that you cannot correctly pass this SP into the tag. Looks like I will have to go with a text parameter which I was trying to avoid. Thanks for the input
    Senior Member alexo4141's Avatar
    May 25, 2011
    Québec, Canada
    548
    01:59 AM
    The Yes/no parameter doesn't need to be a shared parameter unless you really want it to be in a schedule
    In my test, only the text parameter was shared but I also tried with that possibility and it works fine.
    Attached Thumbnails Attached Thumbnails shared parameter.jpg   Footing Parameters.jpg   result.jpg   Tag Label.jpg
    October 14, 2011
    21
    10:59 PM
    RE:
    Quote Originally Posted by alexo4141 View Post
    Wow! Thanks alexo! That is exactly what I was looking for. I knew I was missing something simple. Thank you very much!
    Northern California
    3,572
    10:59 PM
    Rep for you!!!
    May 25, 2011
    Québec, Canada
    548
    01:59 AM
    Rep for you!!!
    Wow my first Green Card!
    Thank You Guys
  1. Shared Parameter Possibility
    Last Post: November 27th, 2011, 08:57 PM
  2. Shared Parameter Woes
    By MPwuzhere in forum Architecture and General Revit Questions
    Last Post: August 18th, 2011, 03:51 PM
  3. shared parameter types
    Last Post: June 17th, 2011, 09:11 PM
  4. Convert Project Parameter to Shared Parameter
    Last Post: January 5th, 2011, 07:35 AM
