Help before I waste more time. Is there anyway to get a generic annotation label to be always vertical.
MONUMETRIC Video mmt-volt
Generic Annotation Always Vertical
This topic is closed.
check off "rotate with element"?Martijn de Riet
Professional Revit Consultant | Revit API Developer
MdR Advies
Planta1 Revit Online Consulting -
Martijn de Riet
MdR Advies
Planta1 Revit Online ConsultingComment
I thought "rotate with component" was for Tag families, I am not really sure it does anything for straight "Generic Annotation" Families
I am not sure if there is a built in way to solve this problem, but one way may be to nest in the text element as a separate Generic Annotation family, then all you need to do is place one for each orientation of the family, you can then control which label shows with a visibility family
It would require manual adjustment for each placement, or you could just make two types if that is easier..Comment
I don't get these kind of quirks. Why put the check in, if it doesn't do anything??? So make it work, or delete it all together...Martijn de Riet
MdR Advies
Tried this approach but seems clunky. "Always vertical" seems like a simple request for annotation ??Mark Balsom
If it ain't broke, fix it till it is.Comment
Edit: Moved this thread out of the Wish List forum! Mark has created a new thread with the new formatting. I don´t like to delete a thread... so this...
Channel: Out There
Applies to: - All Verticals
New Feature / Problem:
I feel there is a need for "orientation control" over generic annotation....-
Channel: 2011 Archive
I want to make a simple label but I cant edit it. What I am trying to do is create a 'warning triangle' but I want a space inside where I can put a number...
In a model with a project linked in. The linked project has a component with a generic annotation nested within it. Go to VV > Revit Links > Annotation...
I have created a generic annotation, and assigned it to a plumbing fixture. However when I connect the cold water to the fixture, it automatically changes...
Channel: MEP - Family Creation
July 18, 2016, 01:23 PM -
MONUMETRIC Anchor B sticky footer - 7ba6
