Thread: Offsets, Default Elevations, and Elevations
    December 17, 2010
    08:35 PM
    Hi y'all,
    We're experiencing something perplexing. We have a ton of content that we've been using for three or more years. It all worked fine in 2009 and 2010. In RMEP 2011, we're coming across a new Height instance parameter. And it's not the same value as the Default Elevation we built into the Family. I took screen captures showing all the Instance and Type values from within the Family Editor and all the Instance and Type values from after placing/loading it in the Project. Suddenly I have a new Instance Constraint called Elevation (in addition to the default Offset). Has anyone else seen this? A known issue? An upgrade? Did we break our Template?
    Any advice is most appreciated!
    -LC
    03:35 AM
    Could you post the screen captures?
    December 17, 2010
    08:35 PM
    Screen capture:
    Screen capture of properties compared: Click image for larger version.
    Member Jrobker's Avatar
    Salt Lake
    178
    08:35 PM
    this link here will explain your problem (last post)
    December 12, 2010
    Paradise, CA
    52
    08:35 PM
    I'm running into this in Revit Arch 2011 as well (default mounting heights for toilets, urinals, etc.). Can anyone say if this has been fixed in 2012?
    4,442
    04:35 AM
    A spot of thread necromancy...
    I've been asked how (if at all) can we get the installed height of our face-based families - but for the life of me I can't see the "Default Elevation" or "Offset" parameter as a field option in schedules.
    Associating an instance-based SP with "Default Elevation" sticks the entered value, and there doesn't appear to be a way of having a reporting parameter work either.
    Personally, I'd have the elements dimensioned in elevation (we produce the drawings after all) and be done with it - but there's a lot of mileage in being able to "get" that info. in the future - so there must be a way.
    03:35 AM
    why doesn't the reporting parameter work? Just need to use ALL refplanes and NO geometry to set it to...
  1. Accent Striping in Architectural Elevations
    Last Post: June 11th, 2015, 03:04 PM
  2. Interior elevations and elevation callouts
    Last Post: December 28th, 2011, 09:25 PM
  3. Crop Region in Elevations
    Last Post: May 27th, 2011, 02:46 PM
  4. Elevations
    Last Post: March 31st, 2011, 12:32 PM
  5. Walls not showing in structural elevations
    Last Post: December 14th, 2010, 12:03 AM
