Results 1 to 10 of 11
Thread: Hanger Columns
    November 28, 2011
    Ontario, Canada
    154
    06:55 AM
    Hanger Columns
    Hello All
    I have two high beams and and I need to put in two hanging columns. Can anyone tell me how to do that
    Thanks in advance
    Kevin
    Alex Cunningham's Avatar
    Northern California
    3,576
    03:55 AM
    Go to the level where the top of your column will be. Start the column command. Change the setting from Height to Depth and select the level to which you want the bottom of the column to attach. (I think they can be the same level for top and bottom) Finaly after placement you can edit the level offsets of the column to suit your needs.
    November 28, 2011
    Ontario, Canada
    154
    06:55 AM
    Alex
    Okay, I did what you have mentioned above, now my problem is this:
    after placing the columns, i tried to used the attached top/base command, and the result is that he hanging column will now attach to the lower beam that I am connecting to and the height of the column is now the same height of the lower beam. when I try to attach the hanging column to the u/s of the high beam, the hanging column and the lower beam lose their connection and now don't meet.
    do yo have any ideas?
    Northern California
    3,576
    03:55 AM
    Not totaly sure what your problem is. Can you show pictures.
    November 28, 2011
    Ontario, Canada
    154
    06:55 AM
    Alex
    As requested, here area a couple of pictures for the connection i am trying to get with these hanger columns.
    Connect1.png: show the hanger column connected to the higher beam and coming down to connect to the short horizontal beam that is connected to the column. this the result when i use the "attached top/base" command. I need to get the hanger column to connect to the u/s of the lower beam
    Connect2.png: shows what happens to the hanger column when i use the "attached top/base command" and attach it the top or bottom of the beam.
    Hopes this helps give you a better idea.
    This is literally my first revit project, so please bear with me if I don't understand a question in your reply.
    Sorry forgot to add the pictures
    thanks
    Kevin
ID:	6022   Click image for larger version.
    December 12, 2010
    New York
    322
    01:55 PM
    I can't see the pictures.
    November 28, 2011
    Ontario, Canada
    154
    06:55 AM
    pictures uploaded
    Northern California
    3,576
    03:55 AM
    Attach the bottom of the col to the lower beams then add an offset to the bottom of the col??? Can this be done?
    November 28, 2011
    Ontario, Canada
    154
    06:55 AM
    I have got it to work. I noticed that my base level was set to the top of the pool steel, so I think this was the problem. I didn't see a selection to be unconnected so what I have done is that I attached the hanger column to the underside of the higher beam than I have entered in the depth of the beam as the base offset to get the column to the underside of the beam.
    I was hoping there might be another way so it would be automatic and that I don't have to do this everytime. but if this the only way to make it work than i'm okay with this.
    here is a picture of my result. The column is highlighted in red.
    Thanks for the help everyone
    Kevin
    3,167
    03:55 AM
    Seems like Adriano's post ought to be split to a new thread?
  1. Wall Sweep With Columns
    Last Post: January 3rd, 2012, 02:53 PM
  2. Zero material volume for columns!
    Last Post: December 27th, 2011, 05:11 PM
  3. Slabs at Columns
    Last Post: October 25th, 2011, 08:00 PM
  4. Resize Revision Schedule Columns
    Last Post: February 15th, 2011, 09:24 AM
  5. Schedule Columns
    Last Post: January 25th, 2011, 06:21 PM
