I am a new user of ASD 2011 version. I have a building frame model which I designed using STAAD Pro.
The model has 4 floors framed with large openings in the floors and openings for stairs. The Work Frame Buttion only allows me to put the outside beams to the outside columns Workframe icon has elements that are 4 sub buttons to make changes to a work frame; add node, delete node, add line, and delete line.
I can't figure out how to add a node to a beam wire. The way it is set up on the command line makes no sense. Addig lines is not too hard to figure out, but adding nodes is hard. If you know how to do this please reply with a detailed explnation.
Thanks for helping!
Billbe
Thanks for helping!
Billbe
