Revit viewports have a parameter called "Show Extension Line". The Type Properties dialog offers us "Yes", "No" and "When multiple viewports". This post deals with the wordy one.
The "When multiple viewports" option is meant to make it easier to leave off a view title when you are only putting one view on the sheet. Most of the time the sheet title is the same as the viewport title, like for overall plans. Seems a bit redundant to put a view title on too?
Unfortunately using it means we have to give up the option of having the viewport title extension line snapping into alignment with other viewport extension lines. I'm referring to the line that shows up when you check the box for "Show Extension Line".
If you are used to these lines snapping into alignment with one another, they won't when you use the "When multiple viewports" option. I captured a short video to help see it in action.
