Thread: Auto Cavity End Closure and Continuous Cavities
    Moderator mark b's Avatar
    NSW Australia
    1,431
    08:28 PM
    Here is an old one but a good one.
    If you want a double brick wall with cavity to join on ends and intersecting walls to create a continious cavity automatically here is how.
    1.Duplicate or create a normal double brick wall (image1)
    2.Now you have to delete the "function" from the material that is outside
    the core boundry. (image2)
    There is a trick here Revit will not let you just select and delete the whole
    function line. You have to select just the function type ie. "finish" and delete
    and leave the number in brackets ie.(4) (image3) Then press OK then the function will
    be gone.
    Set wrapping at ends to "exterior" all done.
    November 8, 2017
    07:28 PM
    Hi Mark,
    An old thread I know, although I can't seem to find any other tips on how to achieve this outcome, and I've followed the steps you've outlined without any luck. I'm unable to delete the function separate from the bracketed [4]. Any advice would be appreciated.
    Thanks.
    KJR
  1. Core Boundaries and Wall Closure ?
    Last Post: May 13th, 2011, 10:16 AM
  2. Beam Wall End Cutback
    By djnelson75 in forum Structure - General Questions
    Last Post: April 19th, 2011, 11:14 PM
  3. Dislocating n Auto Delete Slab
    By Yogesh in forum Architecture and General Revit Questions
    Last Post: March 22nd, 2011, 11:45 AM
  4. High End Cabinet Families
    By Wadeshuey in forum Architecture and General Revit Questions
    Last Post: February 3rd, 2011, 12:44 AM
