Results 1 to 9 of 9
Thread: Revit 2012 and plotting to Kip 3000
    Member KimArndt's Avatar
    February 17, 2011
    Denmark
    172
    02:51 PM
    Hi forum
    We are currently in the process of upgrading from 2011 to 2012. However we are having massive problems when wanting to plot to our Kip 3000.
    I can choose the plotter from the list, and get a preview, but if I want to change papersize, we have to click Properties, (The papersize do not change in the the preview nor the plot, if changed in the Setup dialog), but Revit chases the moment you just as much as think of clicking the botton..
    Of cause we have no problems doing the above in 2011, other than I think it's weird the papersize don't change in Setup...
    This behavior is consistent throughout the office, all have Update 2 installed. Even tried a fresh install - crash, and with Update 1, same result..
    The Kip is running 5.13 which AFAIK is the latest..
    Thinking this is a driver related problem? I've read a blog posting the same problem as this, but no direct solution is added, other than Kip will update the drivers ASAP. Blog post from April I think..
    Anyone have any suggestions on what is going on here? Am I missing something perhaps? :-)
    Melbourne, Australia
    1,145
    10:51 PM
    Hi Kim,
    It is a known problem, and until a new driver is available (assuming it works or course), there is not much one can do except to print to pdf and then from pdf to your KIP printer.
    FWIW, I gave up printing directly to any printer ages ago (I have never been able to get the collate function to work directly from Revit) and ended up writing a little AutoHotKey script to automate printing to pdf. btw, my pdf printer of choice is pdf creator - free and has worked well with all versions of revit thus far.
    February 17, 2011
    Denmark
    172
    02:51 PM
    Thanks Ian, that was what i was afraid of, but OK. Just hoping this will be fixed i 2013 - either that, or just getting used to plot to PDF, maybe KIP will get it together someday..
    Going to be rough, telling my coworkers this in the morning.. -Might be easier convincing the boss to buy a whole new plotter..
    Member gwnelson's Avatar
    Westchester, New York, United States
    157
    08:51 AM
    We have the Kip 3000 too, and I make it work by printing to PDF first & then printing to the Kip via the "Print Request" app. This kills two birds, actually: the PDF becomes the perfect attachment to send to a client or elsewhere.
    February 17, 2011
    Denmark
    172
    02:51 PM
    Yes, I see how that is a nice "bonus".. Please tell me more about the "Print Request" app, haven't heard about it before.
    "OMG I killed Revit"
    dzatto's Avatar
    5,273
    07:51 AM
    I wonder if you could run the 3100 drivers? That's what I plot to, and it works fine.
    I know we used to use newer drivers with older HP printers and it worked. Maybe it's worth checking out?
    February 17, 2011
    Denmark
    172
    02:51 PM
    Okay Dan, I'll try this today. I'll have a talk with a KIP specialist today, maybe he can tell me more, about running the driver you describe on our plotter..
    dzatto's Avatar
    5,273
    07:51 AM
    Just to clarify, I actually have the 3100 plotter. I'm not running 3100 drivers with a 3000 plotter. But it still may be worth asking them.
    February 17, 2011
    Denmark
    172
    02:51 PM
    Okay, time went by, sorry for the wait..
    My problem was solved by updating the driver.. figures I couldn't read and compare two numbers.. Too much I guess..
    Anyway, everything is working as I should, even the boss is happy, not having to buy a new plotter..
  1. Plotting Issue
    By Yogesh in forum MEP - General
    Last Post: April 18th, 2012, 04:39 PM
    Last Post: October 21st, 2011, 10:46 PM
  3. Printing (plotting) to scale
    By Will P. in forum Architecture and General Revit Questions
    Last Post: September 22nd, 2011, 08:24 PM
  4. MEP-plotting
    By stratoflyer76 in forum MEP - General
    Last Post: August 17th, 2011, 10:29 PM
  5. Plotting in Revit
    By TeresaS in forum Architecture and General Revit Questions
    Last Post: December 22nd, 2010, 09:29 PM
