Thread: Automatic Sizing
    Member Gabriel Black's Avatar
    April 6, 2011
    Belgium
    203
    06:16 PM
    Automatic Sizing
    How do I define sizing for automatic pipe sizing?
    I get that I click a pipe on the system then click the duct/pipe sizing calculator but how can I define the pipe sizing as per our company standards? We have a manual method at the moment where we look up on a table and see that a flow rate (velocity only) of between x & y would require a copper pipe diameter of 1/2" and a flow rate of between y & z would require a copper pipe diameter of 5/8" etc.
    Where can I set that?
    By the way, I did quite a lot of fiddling to get 'flow' through the piping systems I made. It was all to do with the connectors; their flow rates, preset or calculated and the Hydronic Return or Supply thing...but it works now!
    Ciao for now.
    Junior Member oj manlapaz's Avatar
    October 14, 2011
    Philippines
    42
    11:16 PM
    I believe it is controlled by the Mechanical Settings under Pipe Settings > Sizes.. Those checkboxes under the column "Used in Sizing". Once cleared they won't be used for the Automatic sizing in MEP... Please correct me if I'm wrong..
  1. Curtain wall panel not re-sizing correctly
    By Morphus1 in forum Architecture - Family Creation
    Last Post: October 30th, 2011, 06:28 AM
  2. Re-sizing 3d Camera Views
    Last Post: June 8th, 2011, 11:52 AM
  3. Dimension - Automatic Spacing?
    By Scott_CJDH in forum Architecture and General Revit Questions
    Last Post: March 8th, 2011, 08:49 PM
