Thread: Controlling Lineweights in Exploded Axo Drawings (Displaced Elements)
    October 9, 2019
    12:22 AM
    Question Controlling Lineweights in Exploded Axo Drawings (Displaced Elements)
    I'm working on an exploded axo drawing of a rather complicated wooden structure, and was quite delighted to have found the Displace Elements tool which makes things quite a bit easier than I thought it would.
    Where I'm running into issues is controlling the lineweights of the elements in the drawing. Basically what I want to do is thicken the profile lines of each distinct element (as you would in a traditional axo), but I've learned that the Lineweight tool won't work with displaced elements/displacement sets... quite a limitation. Additionally, detail lines on a drafting view laid on top of my model view won't work because the structure is too complicated to outline without my detail lines snapping to the model. I'm also not sure that a V/G override will achieve what I want, because editing the weight of the projection lines will also thicken the "folds" instead of just the outer profile of the object.
    Is there a way to accomplish what I'm hoping for that doesn't involve essentially free-handing detail lines? Any advice would be greatly appreciated.
    1,509
    01:22 AM
    The first thing that comes to mind is sub categories or filters, but I have never worked with Displaced Elements, so no idea if those work with that.
    3,192
    06:22 PM
    3 Not allowed! Not allowed!
    I haven't tried it myself, but I wonder if Silhouettes might work for this?
    Click on the Visual Styles icon (next to the View scale), then pick the top line - Graphic Display Options...
    Then pick a Line Type for the edges
    October 9, 2019
    12:22 AM
    This is precisely what I was looking for, thank you DaveP! I was expecting I would need a much more complicated workaround, but I'm pleasantly surprised to see that there's an actual Silhouette setting.
    Last Post: July 13th, 2015, 01:45 PM
  2. Title block Displaced
    By vivek in forum Architecture and General Revit Questions
    Last Post: May 19th, 2015, 11:38 PM
  3. Revit OpEd: Displaced Elements Views and Path Wish
    By Revit OpEd in forum Blog Feeds
    Last Post: May 16th, 2013, 04:15 PM
  4. Reliability of lines from exploded Autocad drawings
    By kpcarch in forum Architecture and General Revit Questions
    Last Post: April 2nd, 2013, 10:41 AM
  5. Lineweights and joined elements
    By Alfienoakes in forum Architecture and General Revit Questions
    Last Post: December 10th, 2012, 04:06 PM
