Thread: Revit Family - Rotational Problem
    April 6, 2015
    05:32 AM
    https://i.imgur.com/nOnwwcn.png
    The question is in the image. But I'm essentially trying to create a LOD400 roof panel that can rotate both vertically (for roof pitch) and laterally (for roof direction). I can't for the life of me find anything online that comes close to answering this problem. Anyone have any ideas?
    Member Bjorn_K's Avatar
    April 8, 2011
    Rotterdam, Netherlands
    354
    06:32 AM
    make the panel, nest it into a Family with a Refline to rotate for pitch, host on that Refline, nest that into a family with a Refline for direction.
    3,127
    09:32 PM
    Curiosity strikes... how big is this panel? A shingle? Concrete Tile? Large metal panel?
    How does the project benefit from digging deeply in this particular rabbit hole? Does a separate roof element for just the material thickness and with a surface pattern applied to it achieve the same goal?
    June 10, 2012
    25
    06:32 AM
    Hello
    I know this is not an answer to your question but I would rotate it manual laterally and veritcal by rotation parameter (Marcellos revolve method).
    Hope you find the solution.
    Skickat frn min iPhone med Tapatalk
  1. Family parameter problem
    By Rulf21 in forum Architecture - Family Creation
    Last Post: September 13th, 2018, 07:03 AM
  2. Adaptive component - beam - rotational profiles
    By James in forum Architecture - Family Creation
    Last Post: March 8th, 2016, 03:33 PM
  3. Revit Family Problem
    By shadab.apex in forum MEP - General
    Last Post: January 3rd, 2013, 02:54 PM
  4. Problem on simple family ! Help me
    By thaihoalu in forum Architecture - Conceptual Massing and Adaptive Components
    Last Post: December 6th, 2011, 09:38 PM
  5. Revit 2012 family problem
    By Chris Needham in forum Architecture and General Revit Questions
    Last Post: July 25th, 2011, 05:58 PM
