Thread: Slanted Angled Column
    March 4, 2012
    6
    10:11 PM
    whats the quickest way to create a slanted angled (on one side) column.
    ootb family is not working as it should.
    3,232
    06:11 PM
    For slanted columns, use the Slanted Column tool from an elevation or section view. I don't understand what you mean by slanted and angled, but if you want to rotate the section of the column, there is a parameter to control the angle of the profile.
    July 26, 2019
    DFW, Texas
    67
    05:11 PM
    Could OP be referring to a double-tapered column--I'm thinking like a concrete pylon.
    Except that is easy enough with Slanted Column.
    March 4, 2012
    6
    10:11 PM
    Basically OOTB column is not what we are looking for, rather then controlling the slope with angle or ration, we prefer a set dimension.
    The column in question looks like this:
    It has a angled chamfer on one side only and it has to be also inclined:
    3,232
    06:11 PM
    ...and, have you tried to model this with the Slanted Column tool?
    March 4, 2012
    6
    10:11 PM
    I tried the slanted column tool, but it has only options of angle or ratio, in addition it attaches itself to floor.
    This is seems more hands on option, where I can control the distance between bottom vs top points.
    3,232
    06:11 PM
    I made a test, and I don't see any difficulty in stretching the slanted column. I don't understand what the difficulty is. The column has an option to be point driven instead of angle driven. Then I chose point driven and stretch the column using the blue dots, not the blue arrows.
  1. Slanted structural column - planview projection/cut style
    By asteckpi in forum Structure - Family Creation
    Last Post: July 11th, 2018, 03:56 PM
  2. Slanted column Alignment
    By Dimitri Harvalias in forum Architecture and General Revit Questions
    Last Post: October 19th, 2015, 08:20 PM
  3. angled column
    By Luckeyluc in forum Architecture - Family Creation
    Last Post: January 13th, 2015, 10:02 PM
  4. Mirroring a slanted column
    By Toots in forum Architecture and General Revit Questions
    Last Post: March 11th, 2014, 12:49 AM
  5. Slanted Column to a beam intersection - detail lines
    By jh75 in forum Structure - General Questions
    Last Post: April 14th, 2011, 01:23 AM
