Results 1 to 8 of 8
Thread: Copying Parameters - Mass -> Mass Floor
    March 13, 2012
    63
    08:38 AM
    We often do very large master-planning exercises, where huge sites are broken down into smaller sites. Said sites will have a Block #, and each Block may be broken into Phases and sub-buildings. So one block could have 2 phases and 1 building in Phase 1 and 2 buildings in Phase 2.
    To complicate things further, each floor on a given block may have different uses... so a lower level may be office/retail with a tower above.
    Our solution to this is to create shared parameters for Block, Phase, Building ID, and program. This can then be scheduled and linked into Excel spreadsheets.
    That's all fine and well, but what I really want to be able to do is automatically populate the "Mass Floor" Block/Phase/ID fields with those of the parent Mass.
    What would be the best way to accomplish this with a dynamo script? I've got a "Mass Floor" schedule and a "Mass" schedule. The "Mass Floor" schedule contains the "Mass:Family Name" parameter so I feel like it's possible to create an IF/THEN argument where "IF" the Mass:Family Name is the same, THEN copy the Block/Phase/ID parameters. But I'm new to Dynamo so I don't really know where to start :/
    Any help would be much appreciated!
    EDIT: I do have the ability to copy parameters between fields in the same family, but it's the "copy if these two values match" thing that is tripping me up
    Gold Coast
    2,665
    10:38 PM
    Quote Originally Posted by guitarchitect View Post
    You want to filter the values for each condition - whatever the common parameter value is between parent & child (set it once) - then you will have the correct elements to read from and write to for any other parameters (update every time script is run)
    FilterByBoolMask is a common node but there are other ways too.
    Can you show us where you're at currently with your dynamo script?
    P.S. you can quite often just use cell referencing between excel sheets which may cut down on a lot of the dynamo stuff. I do a lot of development summary spreadsheets using data from revit areas exported to multiple excel sheets, which are then referenced and consolidated into a master sheet as the final product.
    Member Bjorn_K's Avatar
    April 8, 2011
    Rotterdam, Netherlands
    342
    02:38 PM
    Turns out the almighty Clockwork has the MassFloor.Mass Node.
    March 13, 2012
    63
    08:38 AM
    Quote Originally Posted by elton williams View Post
    yeah, over the weekend I started to think that maybe Excel is the best place to make the changes and sync things. Problem is, it's harder to have a common workflow that has elements of "do this here, but don't do that here, do that there". If everything comes out of revit and is linked into excel, it's an easier workflow to teach + share. I'm always worried about the potential for mistakes when some of the data gets put into Revit, and some of it is in excel. People forget.
    I wish I knew one of the macro languages because this would probably be simpler/easier than a Dynamo script (in terms of integration into the UI). Each mass has three parameters that I want to copy, and if it's three separate dynamo scripts that would have to run I'm definitely into "is this the right solution" territory.
    Attached is the current dynamo file that I'm working from - a modified version of one that I found on the web. Like I say, I'm new to the world of Dynamo!
    CopyBetweenParams_WIP.dyn
    Gold Coast
    2,665
    10:38 PM
    Bjorn has shown a good way to get the parent mass of a mass floor, now you just need to read the info from the mass parameter and write it to the mass floor parameter -
    Clockwork is an awesome package.
    March 13, 2012
    63
    08:38 AM
    the piece I'm missing is, how do I only run the copy/paste IF it matches another parameter?
    essentially I have, say, 10 masses (blocks), and i want to write the parameter for Block 1 to block 1's floors, Block 2 to Block 2's, etc.
    in the end I think it might just be easier to leave the info to the mass floors alone and do the summing in excel!
  7.    #7
    April 8, 2011
    342
    02:38 PM
    Have you tried the example? Because this:
    is exactly what the example is doing.
    I have no idea how you would arrive at this conclusion if you had tried to make some scripts with some test runs and Revit schedules.
    Must be one of those "to each his own" things.
  8.    #8
    March 13, 2012
    63
    08:38 AM
    nope I haven't tried it yet... but i'll try it soon!
    my "might be easier" comment is just about overall workflow - when it comes to minimizing potential for errors when rolling out a workflow for a number of people of different skill levels, i always start to worry about relying on plugins/scripts/etc. but, i'll have to try it out and see how people like it!
  1. In Place Mass Disappears when Subcategory is changed to Mass Exterior Wall
    By pmrossarc in forum Architecture - Conceptual Massing and Adaptive Components
    Last Post: May 26th, 2017, 09:41 AM
  2. Vertical Mass to conform to roof mass
    By Hilife in forum Architecture - Conceptual Massing and Adaptive Components
    Last Post: March 21st, 2015, 10:37 PM
  3. Floor Curving in 2 Axes off a Mass
    By irneb in forum Structure - General Questions
    Last Post: October 11th, 2014, 01:02 AM
  4. Mass Floor Button
    By mona miller in forum Architecture and General Revit Questions
    Last Post: December 23rd, 2013, 12:48 AM
  5. In a curved mass how to turn only one edge to straight without affecting the mass ?
    By Diaa.Sabri in forum Architecture - Conceptual Massing and Adaptive Components
    Last Post: November 2nd, 2013, 10:34 PM
