Thread: RFO Benchmark v3.2 2020 results
    Rotterdam, South Holland
    3,066
    05:11 PM
    Please post your RFOBenchmark V3.2 results for the 2020 products here.
    Comments and suggestions should be made in the RFOBenchmark v3.X thread. The download is there too.
    Note: To condense your results, click Go Advanced, highlight the results, then click the code button (the one with a #).
    Thanks!
    Gordon
    1,347
    05:11 PM
    WOOT the 2020 benchmark is out !!
    Let me be the first one to post my results:
    Code:
    RVT 2020 - Full_Simplified set - 2019.09.09 @ 21.31.24 on WORKSTATION.txt
        RFO Benchmark v3.2 (build 01.05.2018)
        RevitForum.org
    Run on Revit 2020.1
    Model creation benchmark
        4.27   opening and loading the custom template
        9.57   creating the floors levels and grids
       14.41   creating a group of walls and doors
       25.90   modifying the group by adding a curtain wall
        8.90   creating the exterior curtain wall
        6.86   creating the sections
        2.93   changing the curtain wall panel type
       10.88   creating area plans
        1.48   creating and applying view template
       85.20   TOTAL
    Graphics
        4.57   activate View Styles view
        0.95   change view to Wireframe
        0.07   change view to Hidden
        0.28   change view to Shaded
        0.30   change view to Consistent Colors
        0.28   change view to Realistic
        0.70   refresh Wireframe Line view x10
        2.92   refresh Hidden Line view x10
        3.12   refresh Shaded view x10
        2.95   refresh Consistent Colors view x10
        3.73   refresh Realistic view x10
        0.34   activate View Cube view
        2.08   rotate view x1
       22.29   TOTAL
    Notes:
    TEST CONDITIONS:
    Mfr: System manufacturer
    Model: System Product Name
    CPU: Intel(R) Core(TM) i7-8086K CPU @ 4.00GHz
    Max Clock Speed: 4.008Ghz
    Number of Processors: 6
    Number of Logical Processors: 12
    Total Physical Memory: 32GB @ 3200 3200 3200 3200Mhz
    Drive Type: local Disk (NTFS)
    Drive Model: Samsung SSD 970 EVO Plus 500GB
    Graphics Card: NVIDIA GeForce GTX 1070 Ti
    Graphics RAM: 3.9990234375GB
    Driver version: 25.21.14.1967
    DPI Scaling: 100%
    Member remiscs's Avatar
    May 18, 2015
    Las Vegas, NV
    241
    08:11 AM
    Production machine. 9900k w/tune
    Code:
    RVT 2020 - Full_Simplified set - 2019.08.25 @ 11.22.32 on DESKTOP-JOMGR58.txt    RFO Benchmark v3.2 (build 01.05.2018)
        RevitForum.org
    Run on Revit 2020 FCS
        3.89   opening and loading the custom template
        9.78   creating the floors levels and grids
       14.79   creating a group of walls and doors
       26.74   modifying the group by adding a curtain wall
        9.00   creating the exterior curtain wall
        7.09   creating the sections
        2.96   changing the curtain wall panel type
       10.55   creating area plans
        1.46   creating and applying view template
       86.26   TOTAL
    Graphics
        4.46   activate View Styles view
        0.29   change view to Shaded
        0.31   change view to Consistent Colors
        0.29   change view to Realistic
        0.68   refresh Wireframe Line view x10
        2.98   refresh Hidden Line view x10
        3.13   refresh Shaded view x10
        2.97   refresh Consistent Colors view x10
        3.83   refresh Realistic view x10
        0.35   activate View Cube view
        2.13   rotate view x1
       22.44   TOTAL
    Notes:
    TEST CONDITIONS:
    Mfr: Remis Computer Solutions
    Model: Anvil-R
    CPU: Intel(R) Core(TM) i9-9900K CPU @ 3.60GHz
    Max Clock Speed: 3.6Ghz
    Number of Processors: 8
    Number of Logical Processors: 16
    Total Physical Memory: 32GB @ 3200 3200Mhz
    Drive Model: CT1000P1SSD8
    Graphics Card: NVIDIA GeForce RTX 2060 SUPER
    Driver version: 26.21.14.3170
    DPI Scaling: 100%
    Standard test
    Code:
    RVT 2020 - Full_Standard set - 2019.08.25 @ 11.26.02 on DESKTOP-JOMGR58.txt    RFO Benchmark v3.2 (build 01.05.2018)
        RevitForum.org
    Update
        8.86   update previous version file
        3.88   opening and loading the custom template
        9.70   creating the floors levels and grids
       14.64   creating a group of walls and doors
       26.68   modifying the group by adding a curtain wall
        8.87   creating the exterior curtain wall
       10.47   creating area plans
       85.74   TOTAL
    Export benchmark
       49.60   export all views as PNGs at 300 dpi
       45.46   export all views as DWFs
       71.66   export all views as DWGs
       48.01   print all views as vector *
       77.11   print all views as raster *
    Notes:
    Render benchmark
       46.30   render
    Graphics - Standard View
        4.45   activate View Styles view
        0.34   change view to Wireframe
        0.54   change view to Hidden
        0.76   change view to Shaded
        0.73   change view to Consistent Colors
        1.29   change view to Realistic
        0.59   refresh Wireframe Line view x10
        2.57   refresh Hidden Line view x10
        2.75   refresh Shaded view x10
        2.61   refresh Consistent Colors view x10
        2.90   refresh Realistic view x10
        2.07   rotate view x1
       21.94   TOTAL
    Notes:
    TEST CONDITIONS:
    Model: Anvil-R
    DPI Scaling: 100%
    RAW DATA:
        8.953    8.832    8.801   update previous version file
        3.894    3.891    3.867   opening and loading the custom template
        9.691    9.680    9.742   creating the floors levels and grids
       14.797   14.547   14.570   creating a group of walls and doors
       26.770   26.609   26.652   modifying the group by adding a curtain wall
        8.801    8.848    8.953   creating the exterior curtain wall
        7.102    7.082    7.082   creating the sections
        2.969    2.922    2.914   changing the curtain wall panel type
       10.438   10.453   10.531   creating area plans
        1.547    1.430    1.473   creating and applying view template
       49.555   49.613   49.629   export all views as PNGs at 300 dpi
       45.531   45.430   45.406   export all views as DWFs
       71.672   71.875   71.438   export all views as DWGs
       48.059   47.996   47.980   print all views as vector
       77.109   77.215   76.992   print all views as raster
       44.098   50.750   44.059   render
        4.461    4.445    4.441   activate View Styles view
        0.340    0.344    0.348   change view to Wireframe
        0.535    0.559    0.539   change view to Hidden
        0.750    0.762    0.754   change view to Shaded
        0.734    0.719    0.738   change view to Consistent Colors
        1.297    1.301    1.285   change view to Realistic
        0.590    0.594    0.598   refresh Wireframe Line view x10
        2.559    2.578    2.566   refresh Hidden Line view x10
        2.738    2.773    2.734   refresh Shaded view x10
        2.602    2.621    2.594   refresh Consistent Colors view x10
        2.883    2.918    2.887   refresh Realistic view x10
        0.340    0.344    0.340   activate View Cube view
        2.059    2.113    2.051   rotate view x1
    Member kubsix's Avatar
    March 31, 2011
    Quad Cities, Illinois
    296
    10:11 AM
    i7-8700K CPU @ 3.70GHz w/ OC
    Code:
    RVT 2020 - Full_Simplified set - 2019.09.13 @ 08.48.28 on JDK1826BOX10.txt
        RFO Benchmark v3.2 (build 19.08.2019)
        RevitForum.org
    Run on Revit 2020.1
        3.27   opening and loading the custom template
        9.18   creating the floors levels and grids
       14.90   creating a group of walls and doors
       26.25   modifying the group by adding a curtain wall
        9.30   creating the exterior curtain wall
        7.65   creating the sections
        3.15   changing the curtain wall panel type
       10.97   creating area plans
        1.60   creating and applying view template
       86.27   TOTAL
    Graphics
        3.78   activate View Styles view
        1.02   change view to Wireframe
        0.31   change view to Shaded
        0.33   change view to Consistent Colors
        0.31   change view to Realistic
        0.78   refresh Wireframe Line view x10
        3.40   refresh Hidden Line view x10
        3.40   refresh Shaded view x10
        3.24   refresh Consistent Colors view x10
        4.09   refresh Realistic view x10
        0.37   activate View Cube view
        2.73   rotate view x1
       23.83   TOTAL
    Notes:
    TEST CONDITIONS:
    Mfr: BOXX Technologies
    Model: APEXX S3
    OS: Microsoft Windows 10 Enterprise64-bit
    CPU: Intel(R) Core(TM) i7-8700K CPU @ 3.70GHz
    Max Clock Speed: 3.696Ghz
    Total Physical Memory: 32GB @ 2667 2667Mhz
    Drive Model: Samsung SSD 960 PRO 512GB
    Graphics Card: NVIDIA Quadro P1000
    Driver version: 26.21.14.3039
    DPI Scaling: 100%
    Code:
    RVT 2020 - Full_Standard set - 2019.09.13 @ 08.53.57 on JDK1826BOX10.txt
        RevitForum.org
    Run on Revit 2020.1
    Update
        8.14   update previous version file
        3.15   opening and loading the custom template
        9.07   creating the floors levels and grids
       15.02   creating a group of walls and doors
       26.35   modifying the group by adding a curtain wall
        9.24   creating the exterior curtain wall
        7.57   creating the sections
        3.13   changing the curtain wall panel type
       10.83   creating area plans
        1.58   creating and applying view template
       85.94   TOTAL
    Export benchmark
       51.37   export all views as PNGs at 300 dpi
       46.16   export all views as DWFs
       75.50   export all views as DWGs
       51.94   print all views as vector *
       79.27   print all views as raster *
    Notes:
    Render benchmark
       54.86   render
        3.88   activate View Styles view
        0.38   change view to Wireframe
        0.62   change view to Hidden
        0.81   change view to Shaded
        0.83   change view to Consistent Colors
        1.37   change view to Realistic
        0.67   refresh Wireframe Line view x10
        2.81   refresh Hidden Line view x10
        2.91   refresh Shaded view x10
        2.79   refresh Consistent Colors view x10
        3.06   refresh Realistic view x10
        0.38   activate View Cube view
        2.72   rotate view x1
       23.23   TOTAL
    Notes:
    TEST CONDITIONS:
    Model: APEXX S3
    DPI Scaling: 100%
    RAW DATA:
        8.176    8.133    8.125   update previous version file
        3.162    3.123    3.172   opening and loading the custom template
        9.064    9.053    9.090   creating the floors levels and grids
       14.982   15.043   15.039   creating a group of walls and doors
       26.312   26.490   26.238   modifying the group by adding a curtain wall
        9.309    9.180    9.238   creating the exterior curtain wall
        7.459    7.719    7.539   creating the sections
        3.098    3.121    3.160   changing the curtain wall panel type
       10.691   10.945   10.844   creating area plans
        1.609    1.555    1.578   creating and applying view template
       51.258   51.152   51.691   export all views as PNGs at 300 dpi
       46.338   45.824   46.309   export all views as DWFs
       75.164   74.953   76.371   export all views as DWGs
       51.717   51.793   52.297   print all views as vector
       78.887   79.164   79.762   print all views as raster
       56.330   54.059   54.195   render
        3.727    4.176    3.723   activate View Styles view
        0.373    0.391    0.371   change view to Wireframe
        0.617    0.633    0.625   change view to Hidden
        0.820    0.812    0.805   change view to Shaded
        0.809    0.836    0.848   change view to Consistent Colors
        1.357    1.359    1.383   change view to Realistic
        0.674    0.652    0.684   refresh Wireframe Line view x10
        2.742    2.934    2.766   refresh Hidden Line view x10
        2.953    2.910    2.871   refresh Shaded view x10
        2.830    2.781    2.754   refresh Consistent Colors view x10
        3.062    3.074    3.051   refresh Realistic view x10
        0.385    0.371    0.383   activate View Cube view
        2.703    2.699    2.746   rotate view x1
    Member Geert's Avatar
    February 8, 2011
    150
    05:11 PM
    Hm another I9 9900K but different results?!?
    Using intell performace maximiser to OC (in dummy mode)
    Code:
    RVT 2020 - Full_Standard set - 2019.09.12 @ 17.24.17 on FRACTAL-WIT.txt
        RevitForum.org
    Run on Revit 2020.1
    Update
        9.53   update previous version file
        4.29   opening and loading the custom template
       12.30   creating the floors levels and grids
       17.43   creating a group of walls and doors
       30.01   modifying the group by adding a curtain wall
       10.99   creating the exterior curtain wall
        9.57   creating the sections
        3.52   changing the curtain wall panel type
       13.40   creating area plans
        1.89   creating and applying view template
      103.40   TOTAL
    Export benchmark
       55.44   export all views as PNGs at 300 dpi
       48.28   export all views as DWFs
       79.85   export all views as DWGs
       54.95   print all views as vector *
       84.64   print all views as raster *
    Notes:
    Render benchmark
       44.89   render
        4.77   activate View Styles view
        0.57   change view to Hidden
        0.80   change view to Shaded
        0.79   change view to Consistent Colors
        0.65   refresh Wireframe Line view x10
        2.84   refresh Hidden Line view x10
        3.02   refresh Shaded view x10
        2.85   refresh Consistent Colors view x10
        3.18   refresh Realistic view x10
        0.40   activate View Cube view
        2.39   rotate view x1
       24.01   TOTAL
    Notes:
    TEST CONDITIONS:
    Mfr: Micro-Star International Co., Ltd.
    Model: MS-7B98
    Total Physical Memory: 64GB @ 2133 2133 2133 2133Mhz
    Drive Model: CT500P1SSD8
    Graphics Card: NVIDIA GeForce RTX 2070
    Driver version: 26.21.14.3186
    DPI Scaling: 100%
    RAW DATA:
        9.590    9.516    9.484   update previous version file
        4.289    4.277    4.305   opening and loading the custom template
       12.379   12.328   12.180   creating the floors levels and grids
       17.496   17.328   17.461   creating a group of walls and doors
       29.996   29.902   30.125   modifying the group by adding a curtain wall
       10.836   11.000   11.121   creating the exterior curtain wall
        9.547    9.613    9.559   creating the sections
        3.531    3.535    3.492   changing the curtain wall panel type
       13.394   13.488   13.328   creating area plans
        1.875    1.906    1.891   creating and applying view template
       55.340   55.785   55.191   export all views as PNGs at 300 dpi
       48.480   48.203   48.148   export all views as DWFs
       79.680   79.461   80.394   export all views as DWGs
       55.195   54.961   54.707   print all views as vector
       84.934   84.547   84.441   print all views as raster
       44.961   44.898   44.812   render
        4.754    4.789    4.754   activate View Styles view
        0.387    0.383    0.371   change view to Wireframe
        0.570    0.590    0.562   change view to Hidden
        0.785    0.797    0.816   change view to Shaded
        0.797    0.781    0.785   change view to Consistent Colors
        1.356    1.394    1.359   change view to Realistic
        0.648    0.652    0.660   refresh Wireframe Line view x10
        2.805    2.812    2.894   refresh Hidden Line view x10
        3.000    3.012    3.039   refresh Shaded view x10
        2.816    2.856    2.891   refresh Consistent Colors view x10
        3.148    3.188    3.211   refresh Realistic view x10
        0.402    0.387    0.402   activate View Cube view
        2.394    2.367    2.410   rotate view x1
    May 18, 2015
    Las Vegas, NV
    241
    08:11 AM
    Hello @Geert
    What probably happened is that the Intel performance tool set an all core overclock of say 4.7ghz which disabled your 5ghz boost clock. If this is the recent tool that they released about a month or two ago I am nearly certain that is what happened.
    Another thing, if you have overclocked RAM and the z390 chipset (can only see it is MSI) make sure to enable your XMP profile on the RAM otherwise you may be at 2133mhz. In my testing RAM speed makes a slight difference as well.
    Quote Originally Posted by Geert View Post
    Code:
        RevitForum.org
    Run on Revit 2020.1
    Update
      103.40   TOTAL
    Export benchmark
    Notes:
    Render benchmark
       44.89   render
        2.39   rotate view x1
       24.01   TOTAL
    Notes:
    TEST CONDITIONS:
    Model: MS-7B98
    DPI Scaling: 100%
    RAW DATA:
    February 8, 2011
    150
    05:11 PM
    Hi remisc
    So not overclocking might in the end be a better idea?
    It is the recent tool all right. not a magic bullet than. if there is such a thing. I did not boost ram speed that I know of
    It is the MSI Z390 A-pro. bit of the entrance board of the MSI Z390 line but in theory is all I need. only thing missing, for my needs, is bluetooth
  8.    #8
    February 8, 2011
    150
    05:11 PM
    Uninstalled the intell performance maximizer utility but clockspeed remained limited at 4.7
    Processor core ratio was locked at 47x
    changed this to 50 nd boost speed goes up to 5 GHz now.
    I reran the benchmark and here are the results.
    Code:
    RVT 2020 - Full_Standard set - 2019.09.17 @ 13.28.53 on FRACTAL-WIT.txt
        RevitForum.org
    Run on Revit 2020.1
    Update
        8.91   update previous version file
        4.11   opening and loading the custom template
       11.08   creating the floors levels and grids
       15.90   creating a group of walls and doors
       28.04   modifying the group by adding a curtain wall
        9.95   creating the exterior curtain wall
        8.65   creating the sections
        3.22   changing the curtain wall panel type
       12.11   creating area plans
        1.75   creating and applying view template
       94.81   TOTAL
    Export benchmark
       50.98   export all views as PNGs at 300 dpi
       44.57   export all views as DWFs
       73.90   export all views as DWGs
       50.65   print all views as vector *
       78.40   print all views as raster *
    Notes:
    Render benchmark
       50.91   render
        4.55   activate View Styles view
        0.35   change view to Wireframe
        0.74   change view to Shaded
        0.75   change view to Consistent Colors
        1.27   change view to Realistic
        0.61   refresh Wireframe Line view x10
        2.60   refresh Hidden Line view x10
        2.76   refresh Shaded view x10
        2.62   refresh Consistent Colors view x10
        2.91   refresh Realistic view x10
        2.25   rotate view x1
       22.33   TOTAL
    Notes:
    TEST CONDITIONS:
    Model: MS-7B98
    Drive Model: Samsung SSD 860 QVO 1TB
    DPI Scaling: 100%
    RAW DATA:
        8.871    9.023    8.844   update previous version file
        4.109    4.113    4.098   opening and loading the custom template
       10.992   11.070   11.188   creating the floors levels and grids
       15.902   15.984   15.824   creating a group of walls and doors
       28.848   27.691   27.574   modifying the group by adding a curtain wall
        9.973    9.859   10.016   creating the exterior curtain wall
        8.750    8.656    8.535   creating the sections
        3.250    3.180    3.238   changing the curtain wall panel type
       12.219   12.008   12.094   creating area plans
        1.750    1.758    1.754   creating and applying view template
       50.789   51.066   51.078   export all views as PNGs at 300 dpi
       44.410   44.637   44.668   export all views as DWFs
       73.535   74.480   73.684   export all views as DWGs
       50.730   50.535   50.691   print all views as vector
       78.656   78.059   78.477   print all views as raster
       44.703   50.918   57.117   render
        4.551    4.535    4.555   activate View Styles view
        0.356    0.348    0.356   change view to Wireframe
        0.527    0.551    0.551   change view to Hidden
        0.746    0.738    0.727   change view to Shaded
        0.762    0.762    0.734   change view to Consistent Colors
        1.293    1.277    1.242   change view to Realistic
        0.609    0.617    0.598   refresh Wireframe Line view x10
        2.609    2.613    2.566   refresh Hidden Line view x10
        2.746    2.809    2.734   refresh Shaded view x10
        2.617    2.648    2.590   refresh Consistent Colors view x10
        2.898    2.945    2.894   refresh Realistic view x10
        0.394    0.371    0.379   activate View Cube view
        2.238    2.270    2.246   rotate view x1
    Without any specific overclocking
  1. RFO Benchmark v3.2 2019 results
    Last Post: August 13th, 2019, 04:51 PM
  2. RFO Benchmark v3 2017 results
    Last Post: May 9th, 2018, 08:20 AM
  3. RFO Benchmark v3 2015 results
    Last Post: June 22nd, 2017, 11:39 AM
  4. RFO Benchmark v3 2016 results
    Last Post: May 9th, 2017, 12:00 AM
