Thread: Nested Structural framing doesn't allow control of length
    March 11, 2016
    9
    08:52 AM
    I'm have built a complicated Precast Concrete Riser that Has a Horizontal Tread and a Vertical Stem and Drop Stem. I am trying to nest this Family into another so that I can stack the 2 pieces with the end result resembling Stairs. When I nest the families I'm getting things to work great except I can't get the length to flex, or the extensions to work. The constraints won't stick and flex. Any Ideas how to get this to work? The nested family took at least 40hrs to build so I can't really start from scratch.
    December 11, 2010
    Astana
    142
    08:52 PM
    This is a known Revit flaw, in the family enviropment constraints do not work with beams, based on special structural frame template (assuming you use them).
    I'm afraid you have to create a new generic model based stem family.
    It’s better to attach your family to get right help faster.
  1. Nested Connection in Structural Framing Family RVT 2016
    By DDennehy in forum Structure - Family Creation
    Last Post: January 5th, 2017, 02:45 PM
  2. Linear light nested+ shared, but no control of 'Emit from line length'
    By tjgreatrex in forum Architecture - Family Creation
    Last Post: March 21st, 2015, 12:19 PM
  3. Flip control on structural framing elements
    By Knitro87 in forum Structure - General Questions
    Last Post: March 11th, 2015, 09:32 PM
  4. Adding Cut Length to Structural Framing Tag
    By BaconPancakes in forum Structure - Family Creation
    Last Post: May 14th, 2014, 10:50 PM
  5. Schedule Total Length of Structural Framing
    By Ryan_Javlyn in forum Structure - General Questions
    Last Post: July 3rd, 2013, 05:02 PM
