Thread: Enscape issue with linked files
    Coeur d Alene, ID
    4,824
    08:00 AM
    Mornin' all...
    Anyone know of a fix for Enscape to stop reloading all linked models every time a view is changed the slightest bit? The user that is having this issue said it didn't happen until she exported the model for remote viewing (exe).
    Member scourdx's Avatar
    July 4, 2013
    57
    08:00 AM
    I never run into that issue. Only time I have issue is my texture is downsample from 8k to 1k when I add more 3d objects to the scene. How big or detail is your linked file?
    Junior Member skisouth's Avatar
    Here
    26
    10:00 AM
    Mornin' all...
    You will have to go to the Enscape Menu and select the control button (the start button - top left) and change it to "pause" rather than "play". Make your changes to the model and then switch back to "play" to look at the render. I use this on my larger renders as it is an irritant to wait for the unseen update while you are working. Solves the problem.
  1. BIM Chapters: Enscape Blog Post: CUSTOM SKYBOX IN ENSCAPE
    By BIM Chapters in forum Blog Feeds
    Last Post: July 11th, 2019, 06:13 AM
    Last Post: March 23rd, 2017, 12:45 PM
  3. Issue with Design Options in linked files
    By brett05 in forum Architecture and General Revit Questions
    Last Post: August 1st, 2013, 04:44 AM
  4. Replies: 5
    Last Post: March 6th, 2013, 01:47 AM
  5. Revit OpEd: Linked Files with Linked Files
    Last Post: October 2nd, 2012, 04:15 AM
