Thread: Not snapping when creating beams
    August 4, 2019
    02:04 PM
    Post Not snapping when creating beams
    Hi guys I am just starting to learn Revit so please bear with me I have a problem creating beams because it does not snap on the columns I have created I check the reference level and placement plane as well as the current floor I am working with and it is all in the 2nd floor. I have attached an image showing how while I am creating beams snapping does not work as well as the structural settings I have at the moment.
    Thank you very much for your response.
ID:	37135   Click image for larger version.
    December 11, 2010
    Astana
    188
    12:04 PM
    Hi!
    Not enough information to sort it out. Attach a file, if possible, and a sketch of what should be the result.
  1. Creating cellular beams where the holes align with one another
    By JonesNJ in forum Structure - General Questions
    Last Post: March 9th, 2017, 10:32 PM
  2. Are concrete beams best as slabs or beams should be beams
    Last Post: March 6th, 2017, 09:04 AM
  3. Spot elevations are snapping to edges of beams
    By brett05 in forum Architecture and General Revit Questions
    Last Post: September 18th, 2013, 09:11 AM
  4. 3d snapping gone bad in 2012
    Last Post: October 30th, 2012, 02:21 PM
  5. Beams NOT snapping to beams at same elev. but with different ref. plane
    By sebaldsl in forum Structure - General Questions
    Last Post: March 2nd, 2012, 02:01 PM
